Longcase date problem
digitalpan
Oct 29, 2012
53
London, England
Hi everyone
Just into the workshop is an English long case movement. The name on the dial is William Harris of Chippenham, who is listed as working "about 1770". The dial is a single sheet of engraved silvered brass with a round cut-out in the arch - a figure of Old Father Time holding a scythe, connected to the crutch, rocks back and forth. The clock has a long centre date hand, the days of the month are engraved just inside the Roman numerals. The dial and rocking figure suggest to me a later, early 19th century date.
The clock has been behaving erratically, stopping for no apparent reason, on the most recent occasion stopping in mid-strike. I took the hands and dial off to see the strike mechanism and found this:
The date hand wheel is pushed by a peculiar lever soldered to the intermediate wheel, and seems to sometimes clash with the rack tail when striking. Parts of this mechanism seem to me to be non-original (the detent spring looks newish) so I'm wondering if it's a bodge job. I've not come across this type of date hand mechanism before, and I can't find any references or photos. Can anyone point me to any reference source, or suggest how it should be arranged?
Regards
Ian
13,666
94
It might be that someone misplaced a washer/spacer to set the spacing.
Look at the end play to see if in the right position things clear.
Otherwise it looks like the date arm needs to be reset to clear.
Check all the clearances including the front plate before taking action.
177,526
1,555,872
53,605
Morbier
909
3,054
Illinois Watch Company by Kent
