This clock occasionally stops just before the rack is to be dropped onto the snail. It seems that the gathering pallet is jamming onto the rack's stop pin, which prevents the rack from moving slightly as the rack hook rises.
The rack hook has to move a very small distance because both the rack hook and the rack teeth are slightly slanted and tend to lock together.
The totally-immobilized rack prevents the pin on the hour wheel from pulling up the rack hook to release the rack. This stops the hour wheel and thus the clock at about five minutes to the hour.
I'd removed, polished, and generally improved the rack hook and its pivot, which I originally thought were guilty, and polished every other surface I could think of prior to getting smarter and finally running the clock without its dial. There's no visible corrosion on the rack pin or the gathering pallet, but I'll try polishing and perhaps lubricating this steel-to-steel contact point.
But I'm not at all confident in my diagnosis, for this is perhaps the fourth attempt at curing the problem. Has anyone else run into this sort of symptom?
Mark Kinsler
Mark Kinsler
