This interesting advertising clock has come to the shop for restoration. I can't find much about the Lincoln Electric Clock Company, unless this clock was made by the same firm that produced Hammond style desk clocks at about the same time- which is likely, I guess. The synchronous motor doesn't appear to be a Telechron, at least it's different than those I've worked on previously. The motor does turn when plugged in, with a little help anyway. There is an interesting 4 armed widget that spins around just under the center shaft, just an attention getter, I think. I like the very bold graphics and the large hands, clearly made to impress and attract attention to whatever storefront it hung in. It is made to hang in a storefront window, front edge right to the plate glass. The reverse painted glass dial is about 21" in diameter. There is a socket in the back for a light bulb for illumination. I'll post more photos as the project progresses..
I would appreciate knowing more about this company and seeing other examples of their work.
