LINCOLN CLOCKS
Discussion in 'Electric Horology' started by Wasting Time, May 4, 2005.
  1. Wasting Time
    Wasting Time Guest
    I HAVE SEEN A FEW REFERENCES TO A LINCOLD CLOCK COMPANY - PRODUXING ELECTRIC CLOCKS IN THE EARLY 1900s.
    IS THERE A PLACE I CAN RESEARCH THIS COMPANY'S HISTORY? :confused:
  2. harold bain
    NAWCC Member Donor
    40,087
    46
    Hi Ivan. If you are an NAWCC member, you could use their research facilities. It is not a company that I am familiar with. How is your research on the James Remind-o-timers coming? Harold
  3. Jeffrey R. Wood
    Jeffrey R. Wood Registered User
    Found amongst my "junk" a circa 1930 bakelite so-called "cathedral" style "Lincoln" synchronous electric clock with "ELECTRIC CLOCK CORP. OF AMERICA, CHICAGO" at the bottom of the dial, plus a nearly identical "Royal" which appears to have been made by the same manufacturer. Both are rather cheaply made and NOT self-starting. Don't think these are too rare-- if you keep checking ebaY you are bound to find other examples pictured.
  4. skruft
    skruft Registered User
    Aug 5, 2002
    284
    I have seen many "Lincoln" electrics over the years and all have been of the kind Jeff described, sort of generic cathedral-shaped non-self starting bakelite clocks with round dials, of the kind that were made in the early 30s. They seem reliable, as many do still run after 75 years, but not at all rare. Some other makers made the same or nearly the same style.
  5. Elmo Electric
    Elmo Electric Registered User
    Jul 26, 2016
    17
    IT Consultant
    Atlanta GA
    #6 Elmo Electric, May 9, 2017
Similar Threads - LINCOLN CLOCKS Forum Date
Electric clocks, Electric Horology Friday at 12:52 PM
Smiths Sectric - English Clocks Electric Horology Nov 9, 2017
Lincoln Electric large window display clock, Chicago. Electric Horology Jul 9, 2017
Lincoln spin start by Galter Electric Horology May 8, 2011
Lincoln Electric Brass Lamp with Clock in the base Electric Horology Jun 28, 2010
