Limit No.2 Pocket watch
gebhi
New Member
Feb 28, 2021
49
Recently found my Grandfathers 15J Limit No.2 non magnetic pocket watch. Its in nice working condition however I do not know how to move the hands to correctly change the time. Both front bezel and back cover of its nickle plated case unscrews off. I believe this was used during his Royal Navy Fleet Air Arm days during WW2.
Does anyone know how to correctly change the time on this?
viclip
Jul 20, 2018
773
549
93
Can you post a photo of the dial with the front bezel screwed off?
agemo
Apr 5, 2011
318
352
70
SAINT-NAZAIRE - FRANCE
Hi,
The time is set normally by pulling and running the crown. If it doesn't work, don't insist and go see a watchmaker because in this case there is certainly a problem with the time setting.
Limit Watch Co. / Hirst Bros. & Co.Ltd. uses Swiss movements G. Thommen/Revue and your caliber is a 30L.
Amicalement GG
gmorse
12,337
2,037
Hi gebhi, and welcome to the forum,
If your watch was an official military issue, there should be some numbers and letters stamped on the back.
gebhi
New Member
Feb 28, 2021
49
Thanks for your help. Prior to asking
I tried pulling the crown up but worried I may damage didn't move. This morning after reading comments firmly pulled the crown which worked.
I guess being packed away for decades was little stiff but now seems to keep good time as I'm keeping eye on it. Here is the rear with some pattern on but inside you can see numbers but no crows feet and no date. Are these numbers of watch itself?
Reactions: viclip
gmorse
12,337
2,037
Hi gebhi,
Service issued watches usually have the information about their issuer, type and other details stamped on the outside of the back, often together with the pheon or broad arrow. This example includes the date of issue, 1953.
The number inside the back is often the case number, and the scratched marks are the private codes of previous repairers.
gebhi
New Member
Feb 28, 2021
49
Thanks for info, most likely a private purchase. Interesting to see its been repaired couple of times during its life. Any idea as to its age as I understand the Company was formed in 1912, any idea of its age?
164,923
1,435,153
85,879
deeqdacad
2,872
