• Upcoming updates
Ligne for watches
fuzz1
Mar 30, 2022
92
13
42
Hi
I am a bit puzzled by the ligne measurement for watches.
Saw the conversion of ligne to mm as 1 ligne equivalent to 2.256 mm
But saw a movement advertised as 25.6 mm ligne 11.5.
That makes it not really 11.5
So just wondering if it's really 2,256 mm the ligne
Thank you
gmorse
14,834
3,931
Hi fuzz1,
The conversion factor you mention is correct, it is 2.256, see here for more information. 25.6 mm is 11.34 lignes, so not too far out!
Reactions: fuzz1
fuzz1
Mar 30, 2022
92
13
42
Thank you my friend.
I been browsing the website of cousinsuk and found that the conversion doesn't match.
e.g ETA 956.112 is advertised as 17.2 mm 7.75 ligne
I checked several but the conversion of 2.256 for 1 ligne doesn't come true
gmorse
14,834
3,931
Hi fuzz1,
I think you'll find that they're probably rounding to the nearest quarter of a ligne, (0.564mm), which is quite good enough for most purposes.
Reactions: fuzz1
fuzz1
Mar 30, 2022
92
13
42
Hi
Thank you Graham. I did not realise that it would be insignificant the difference. In watches thought everything needed to be as precise as possible. Close to the real value
Tom McIntyre
Technical Admin
NAWCC Star Fellow
NAWCC Ruby Member
Golden Circle
Aug 24, 2000
85,315
3,003
86
Boston
awco.org
Hi
Precision is only really required in the mechanism. Size of movement and case are style elements and require a lower precision allowance because of the multiple sourcing.
This is an industry issue, not a design issue.
Reactions: gmorse
178,995
1,570,061
54,044
Renegade
909
3,088
Swiss Fake by Kent
