Lever set fix
Discussion in 'Watch Repair' started by BCMC, Feb 9, 2019.
  1. BCMC
    BCMC Registered User
    Dec 27, 2014
    288
    Retired LAPD
    Eagle Idaho
    Working on a nice 18s Seth Thomas. The lever set raised area that your hook your finger nail onto to extract is gone., Has anyone tried to apply heat and hammer another 90 degree ridge? Thanks T
  2. Ticktinker
    Ticktinker Registered User
    NAWCC Member NAWCC Member
    Jul 7, 2015
    1,067
    11
    Construction Inspector
    Houston Texas
    #2 Ticktinker, Feb 9, 2019
    Might have better luck Finding a replacement or making the entire part from metal strap material.
    Also to consider, is if you create a new arm on the existing part by simply bending up more material,
    you may be putting the watch into setting mode by simply having the lever out past the edge of the dial where it would be when you finish and case the movement.
    Also comes to mind is soldering on a piece to create the bend,,, may be a venture that would work.
    A butane torch, borax for flux, ( I use 20 mule team) a hold closed tweezer to hold the part, some jewelers silver solder, (available in watch repair supply sites online) lay the work on the anvil on a bench vise and you are set to go.
    There are experts in metallurgy here that can help you normalize the part after welding.
    In fact if you have other levers laying around you could cut a piece in the middle of the arm and make an easier repair on a flat part, and file and hone it out smooth....
    Good luck and happy hobbying!
  3. Rick Hufnagel
    Rick Hufnagel Just Rick!
    NAWCC Member Donor Sponsor
    Oct 25, 2018
    782
    843
    93
    Plumber
    Pittsburgh pa
    I have a model two transitional bw Raymond that someone mangled the lever to get it to work in a case with a normal lever slot .(this lever was straight and moved side to side instead of pulling out). I tried to undo the bend, and with very little force snapped the lever. So... I have never tried that again. Just figured I'd share my bad experience in hopes that you won't have the same.
  4. Tom Huber
    Tom Huber Registered User
    Dec 9, 2000
    2,953
    94
    Track & cross Country Coach
    Indiana PA
    Rick, sounds like your watch has the Abbots Stem wind conversion. The levers move back and forth.
    Can you show us a pic of under the dial. This will let us know for sure.
    Tom
  5. Rick Hufnagel
    Oct 25, 2018
    782
    843
    93
    Plumber
    Pittsburgh pa
    Hi Tom! No it's not Abbot's, these were made this way. It's an early model 2. Here's the underdial view from a different movement that has also been bent to accommodate a normal lever slot. This one is a few hundred away in serial number. Same grade . 70 b.w. Raymond. My grade 8 md Ogden transitional has the same setup as well. I don't have an Abbot's but I'd certainly like to find a nice example one of these days!
  6. Rick Hufnagel
    Oct 25, 2018
    782
    843
    93
    Plumber
    Pittsburgh pa
    Here's one bwr cased. Notice the slot for the lever is straight. Which means you either have to buy an original cased one, or modify a lever slot to case one, which is a pain because I like these! I'm assuming that's why these levers are bent up so often! It's easier then filing a case.
  7. Rick Hufnagel
    Oct 25, 2018
    782
    843
    93
    Plumber
    Pittsburgh pa
    Just because I already posted the early style. Here's a model 2 example of the later style that pulled out instead of switching side to side.
  8. Marty101
    Marty101 Registered User
    Oct 28, 2007
    612
    57
    Retired-bad back but still movin'.
    Niagara Falls,N.Y.
    Here's the labor of someone who cared-lot's of scars but still a beautiful carry-
    ralph1, viclip and Richard Hufnagel like this.
