I got this lenzkirch at an estate sale. It wouldn't stay running.
Broke it down cleaned it put it back together.
And got it running but it doesn't seem the pendulum is swinging as far as it should.
So it's running fast. 5 minutes in less then 24 hours. Dropped the pendulum and it won't stay running. I'll ad a pic of where the pendulum arcs at on bottom gage.
I'm pretty sure this movement was not originally in this case. It has to do with the bottom bracket on movement and bracket mounted in case were modified to fit each other.
Question is could it be too light of weight not giving out enough power to make a wider arc of the pendulum. Longer arc slower time. Smaller arc faster time kinda thing
