Lenzkirch made date?
Discussion in 'General Clock Discussions' started by rimantas14@gmail.com, Sep 12, 2017.
  1. rimantas14@gmail.com
    rimantas14@gmail.com Registered User
    Jun 1, 2017
    #1 rimantas14@gmail.com, Sep 12, 2017
  2. Walt Wallgren
    Walt Wallgren Registered User
    Aug 16, 2012
    1,131
    Bay Area, California
    Hello rimantas,
    Welcome to the message board.
    George Everett has published a book titled, "Lenzkirch Clocks: The Unsigned Story" and based on his work your clock is from about 1888. There haven't been any formal production records found so all dates are estimations based on what is known but that should get you pretty close. BTW I have a copy of that book and I found it very informative about the history of Lenxkirch.
    Hope this helps,
    Walt
  3. LenzkirchFan
    LenzkirchFan Registered User
    Aug 31, 2002
    271
    Utilities
    Missouri
    Hello rimantas,
    You might want to read my article in the September/October 2014 Bulletin, "Lenzkirch Secrets Revealed". Your movement is a 26 series movement with serial number 61648. It is a second movement indicated by the large 2 stamped between the serial number and the series number 26. Lenzkirch ran a second series of serial numbers for 100,000 clocks and yours is one of those 100,000 clocks. I believe these 100,000 clocks were made sometime between 1875 and 1878. As Walt said, it is hard to determine an exact date that Lenzkirch clocks were made because production records were lost.
    Enjoy your Lenzkirch clock!
    Steve
  4. rimantas14@gmail.com
    Jun 1, 2017
    Thank you very much Walt.
    I read with pleasure this book, how to do it?
  5. rimantas14@gmail.com
    Jun 1, 2017
    Thank you very much.
    I read your article, I liked
  6. Walt Wallgren
    Aug 16, 2012
    1,131
Similar Threads - Lenzkirch made date Forum Date
Early Lenzkirch Vienna Regulator 1 Weight General Clock Discussions Apr 8, 2017
Lenzkirch tall case General Clock Discussions Jan 31, 2017
Info on Lenzkirch 1st Trademark Serial Number General Clock Discussions Nov 27, 2016
Lenzkirch Wall Clock General Clock Discussions Oct 24, 2016
Please help identify year made Lenzkirch General Clock Discussions Aug 30, 2010
