• Upcoming updates
Lenzkirch free swinger
binman
Nov 16, 2011
794
Chatham England
Hi, Being sold on your side of the water , this clock, it has a count wheel, but the only other mark on the rear plate is a large 2Q below that the serial number, I did email this seller but have had no reply, to ask if it was in fact a Lenzkirch movement, what do you think.
Walt Wallgren
Aug 16, 2012
1,223
34
Bay Area, California
HI Binman,
The "2Q"could in fact be an indication of a Lenzkirch movement. That being said, tread lightly. All of the 2Q movements I have seen have a lower S/N than what you would expect, based on production year and also have the Lenzkirch logo. Really tough to guess on this one. Not much to go on.
Good Luck,
Walt
binman
Nov 16, 2011
794
Chatham England
Thanks Walt. I'm just curious, the s/n 44308 is low, gives a date of 1852/53.
Walt Wallgren
Aug 16, 2012
1,223
34
You can't equate the "2Q" serial numbers to the normal dating sequence. I don't have the book in front of me right now but it seems the 2Q dates first appeared around 1890 or so. There is also some debate as to what the significance of the 2Q is. As Albra has rightly said, there is just so much we don't know.
If you do get it, please post some pictures.
Walt
LenzkirchFan
Aug 31, 2002
399
49
Missouri
Walt
I have submitted an article to the Bulletin about dating the 2Q movements. It brings out information that is not widely known and will help everyone know where these clocks fit into the Lenzkirch serial number series.
2Q movements should have the 2nd Lenzkirch trademark on the movement.
Steve
binman
Nov 16, 2011
794
Chatham England
Hi Steve, what do mean by 2nd Lenzkirch trademark, this movement only shows
the 2Q. How can we see your article, I Have two Lenzkirch clocks myself, mantle and wall. Always very interested in this make.
LenzkirchFan
Aug 31, 2002
399
49
Missouri
These clocks were made after Lenzkirch started using their second trademark which is the pine cone and Lenzkirch (see my icon above LenzkirchFan). I have pictures of some 2Q movements without the trademark but they are less common.
My article has not been published yet but it has been reviewed so hopefully, it will be published one of these days. I gather pictures of Lenzkirch movements and clocks and file them by serial number. Right now, I have over 3,000 serial numbered movements documented and I have been able to learn a lot by doing this.
Cheers, Steve
tarant
Jul 6, 2008
1,199
65
Wroclaw
Few months ago I've seen on the net auction the Lenzkirch movement signed 2 Qte, with the SN 277736. This was the only 2Q weight driven and with the classical SN movement I've ever seen.
LenzkirchFan
Aug 31, 2002
399
49
Missouri
Hi have only seen two of these single weight movements with the 2.Qte. The serial numbers are close to each other. I may have more information shortly on this stamp. These are the only weight driven movements that I have seen with the 2.Q.
My article on the 2.Q stamp is in the recently publish Bulletin for September/October.
Steve
LenzkirchFan
Aug 31, 2002
399
49
Missouri
Here is a little more information on this movement. If you enlarge the picture, you will see that the serial number is 277756. I have pictures of this movement and also of movement number 277754 which is exactly like it. It is thought that these were made for the French market and the TÈ is an abbreviation for the French word qualitè. These are the only weight driven movements that I have found with the 2.Q mark. I'm betting that serial number 277755 is the same!
Steve
178,855
1,568,750
54,001
Tracy K
909
3,078
E. Howard & Co. by Steven Thornberry
