lenzkirch bracket clock odd suspension spring adjustment?
Discussion in 'Clock Repair' started by ChrisCam, May 26, 2020.
  1. ChrisCam
    ChrisCam Registered User
    Dec 9, 2017
    1,387
    27
    England
    Hi Guys,
    Just started looking at this Lenzkirch bracket clock. German about 1867 I think. What interests me thus far is the adjustment on the suspension spring. There is a bar with a square end that goes through the dial.
    Has anyone any experience / knowledge of this adjustment and why the quality German firm thought the suspension spring would benefit from these adjustments.
    Chris
  2. bruce linde
    bruce linde Technical Admin
    6,594
    749
    oakland, ca.
    based on the brocot adjuster in french clocks... gives you the ability to regulate from the front of the clock
  3. JTD
    JTD Registered User
    Sep 27, 2005
    7,534
    490
    As Bruce says.
    It is a very useful mechanism - once you have the clock adjusted as well as you can with the pendulum bob, you then can make the final tiny adjustments from the front, with the appropriately sized key.
    This is nothing to do with being a 'benefit' to the suspension spring, but it is of great benefit to the clock owner, and the 'quality German firm' thought it was a good idea, because it is.
    If you can post the serial number of your movement, it should be possible to date it. Personally, I think it is later than 1867, though I may be wrong. Where did you find that date?
    JTD
  4. new2clocks
    new2clocks Registered User
    NAWCC Member Sponsor
    Apr 25, 2005
    2,296
    250
    Pennsylvania
    I agree. I believe that the trademark on the OP's clock was registered in 1875, so that would be the earliest date that the clock was made.
    Regards.
  5. ChrisCam
    Dec 9, 2017
    1,387
    27
    England
    #5 ChrisCam, May 27, 2020
    Thanks for the posts Guys. I found a couple of lists of serial numbers with years and extrapolated from these for the year based on the length of serial number. Have just found this site; George's Antique Clocks
    This states clocks like mine with 1 million stamped on the back means you add the serial number to 1 million to get the date. So as my serial is 9320 it means i think the clock is 1893 or 1894.
    I haven't yet stripped clock as found the fault why it was stopping and am seeing how it goes first. This is my first clock which i have come across that I believe is called a 'ting-tang' clock. It has 2 iron chime rings. How these strike in relation to the hour, half hour etc I am monitoring as no idea yet.
    Cannot see the adjustment on the verge / suspension spring does anything other than alter the tension holding the suspension spring. I take it I am wrong but as yet cannot see why?
    Chris
  6. JTD
    JTD Registered User
    Sep 27, 2005
    7,534
    490
    It raises and lowers it, thus changing the regulation, as if you were altering the bob.
    JTD
  7. JTD
    JTD Registered User
    Sep 27, 2005
    7,534
    490
    Yes, that is a much more likely date.
    JTD
  8. ChrisCam
    Dec 9, 2017
    1,387
    27
    England
    Just raising or lowering the suspension spring in itself would still give the same length. It must alter the effective spring length to make a difference. If I am right are these suspension springs unique to this type of mechanism or if i am wring I still don't get it??
    Chris
  9. new2clocks
    Apr 25, 2005
    2,296
    250
    Pennsylvania
    Chris,
    Your clock was made in 1894, according to the most recent data base on Lenzkirch serial numbers.
    For the record, please provide a picture of the serial number.
    Thanks!
  10. wow
    wow Registered User
    Jun 24, 2008
    4,078
    278
    Retired Music Minister
    Pineville, La. (central La.)
    Raising or lowering the suspension spring also raises or lowers the pendulum bob, right? Therefore raising the spring speeds up the clock and vice-versa.
    Does the clock have an adjustable bob? If so, adjust the bob as close as possible and then use the dial adjuster to fine tune it.
  11. JTD
    JTD Registered User
    Sep 27, 2005
    7,534
    490
    Exactly right. (And as was explained in post #3)
    JTD
  12. ChrisCam
    Dec 9, 2017
    1,387
    27
    England
    Any particular reason you want a picture as opposed to my stating it?
    Chris
  13. new2clocks
    Apr 25, 2005
    2,296
    250
    Pennsylvania
    Your serial number would be one of the lowest / earliest of the "1 Million" series that was made. I have not seen a serial number in the "1 Million" series lower than five digits. Your clock has four digits.
    The picture would be for the sake of posterity and for those who have been accumulating this data on Lenzkirch clocks.
    Regards.
  14. ChrisCam
    Dec 9, 2017
    1,387
    27
    England
    Fair enough, picture uploaded. I have investigated the clock and found the height adjuster was not working as there is a slot in the screw held by a pin which was back to front. the suspension spring is held in the slot of the adjustable screw head and is adjusted by the bar. The pendulum on this clock is fairly heavy so how much reliance you can have on the screw head holding the spring by a millimeter of force is questionable over time I would suspect.
    Anyone know if the drums can be removed without a total strip down on these clocks?
    Chris
  15. shutterbug
    43,260
    1,194
    The time is actually regulated by the chops (the lower part that the suspension spring goes through) affecting the usable length of the actual spring. As you choke up on the spring (a baseball euphemism) it gets shorter and less flexible. That speeds the clock up. Of course the opposite is also true. If you max it out (choke it too far) it will not be able to function at all.
  16. THTanner
    THTanner Registered User
    NAWCC Member Donor
    Jul 3, 2016
    2,608
    191
    Carson City, Nevada
    I am wondering if that is the proper suspension spring. There are longer versions of similar two block springs. The distance the chops can move would take this spring all the way up to the bottom block which would effectively remove the spring from the setup. Perhaps look for a longer such spring, raise the bob accordingly, and plan to keep at least 1/4 inch of suspension spring below the chops when in the full up position?
  17. JTD
    JTD Registered User
    Sep 27, 2005
    7,534
    490
    Having looked more carefully at the photo, I am also wondering if this is the wrong suspension spring.
    JTD
  18. ChrisCam
    Dec 9, 2017
    1,387
    27
    England
    Good point TH.
    Chris
  19. ChrisCam
    Dec 9, 2017
    1,387
    27
    England
    Always appreciate learning something new so the 'chops' are the sliding fit the spring goes into?
    Chris
  20. shutterbug
    43,260
    1,194
    Yes.
  21. new2clocks
    Apr 25, 2005
    2,296
    250
    Pennsylvania
    Thanks, Chris.
    Regards.
  22. wow
    wow Registered User
    Jun 24, 2008
    4,078
    278
    Yes, Chris. If you notice the set-up on many of the little round French clocks, they have adjustable chops rather than adjustable springs like yours. The chops move up and down whereas your spring moves. As Shutt says, it’s where the spring bends that matters.
  23. THTanner
    NAWCC Member Donor
    Jul 3, 2016
    2,608
    191
    Carson City, Nevada
    I also wonder if springs of that era had two feathers? Perhaps something more like this one ??
    #33 Suspension Spring
  24. shutterbug
    43,260
    1,194
    I hadn't noticed that. I think you are right .... but not certain that your example would be the right one.
  25. THTanner
    NAWCC Member Donor
    Jul 3, 2016
    2,608
    191
    Carson City, Nevada
    I don't really know what the right spring would look like, but did they use dual feather springs back then? Would like to know.
  26. JTD
    JTD Registered User
    Sep 27, 2005
    7,534
    490
    French movements with brocot - type adjusters did, if I recall correctly.
    JTD
    THTanner likes this.
  27. shutterbug
    43,260
    1,194
    I've never encountered a dual spring suspension used in conjunction with chops except on French made clocks. That does not mean there aren't any though :)
