LeJour Chrono
Discussion in 'Wrist Watches' started by jim88, Mar 1, 2001.
  1. jim88
    jim88 Guest
    I've got a LeJour chronograph wristwatch probably from the late 1970's. The dial case and steel band are all black like the Porsche models. The movement is a ValJoux 7750 automatic with day and date. I'd like to overhaul it (I do pocket watches) but I'd feel more comfortable with a breakdown of the movement. Does anyone know where I can get that?
    [This message has been edited by jim88 (edited 03-01-2001).]
  2. jim88
    jim88 Guest
  3. Mike Kearney
    Mike Kearney Guest
    I've got an Ebauches tech binder from 1976. I think your movement may be in there. I'll check this evening, and let you know. If anyone else can provide Jim info sooner, please do.
    As to other sources, I suspect AWI has a copy, if you're a member. I'm not(maybe someday). If you are an NAWCC member, you can send a request to the NAWCC librarian, and they will send you a copy if it exists in the library (and I suspect it's there). Details on the NAWCC library page. Just another valuable but often overlooked benefit of NAWCC membership.
    Mike
    [This message has been edited by Mike Kearney (edited 03-02-2001).]
  4. Mike Kearney
    Mike Kearney Guest
    Jim, I have a tech sheet for the 7750 that shows the parts and their names. No service or oiling instructions though. If you want, you can contact me at armillary@netstorm.net
    Mike
