LEFT HAND TAPS AND DIES.
Altashot
Oct 12, 2017
325
96
45
Where do I find a set?
Metric and imperial in the small sizes that are suitable to what we do.
I have a small Swiza alarm clock with a stripped out winding key.
Thank you.
M.
Dushan Grujich
Jun 20, 2003
628
57
Bondi
geocities.ws
Thank you.
M.
G'Day!
It would be much, much cheaper to make exactly what You need, instead of finding and buying a set or two. Just for example, a new set 0.30 - 1.20 mm right hand goes for over a $1K, a left hand would go at least twice as much. So, make your pick.
Cheers, Dushan
Altashot
Oct 12, 2017
325
96
45
Wow! Really, that much!?
So, if I only need one, where do I get it from?
Thank you
M.
Altashot
Oct 12, 2017
325
96
45
I would still like to know who sells these things, no matter the cost.
Whether I choose to by a set or two, or make it myself or have it made, that is my pick.
Thank you.
M.
wefalck
Mar 29, 2011
713
89
Paris
What sizes are you talking about, what precision and how many threads are you expecting to cut ? Left-hand taps are generally more expensive, but can be found on ebay at least for sizes above M1. Smaller ones are indeed likely to be rather expensive.
DeweyC
Feb 5, 2007
2,449
1,009
Baltimore
www.historictimekeepers.com
Thank you.
M.
Ok. One way I read (never tired) was to make a flat tap (tow parallel sides) and turn it in reverse. If I were desperate, I would take a rt. hand screw of the correct size, and grind it to produce a flat tap. Since you are using it in brass, hardening may not be needed.
In addition to eBay, you can also check with material houses like McCaws or Jules Borel to see if they can order you one. Might well be $75; but ...
Now, how are you going to increase the ID of the winding key so that you can tap the correct thread? Are you better off squaring the shaft and fitting the key that way? Have you looked for assortments of winding keys?
What is the OD of the threaded shaft? Someone here may have one.
Altashot
Oct 12, 2017
325
96
45
I have not checked the size or pitch yet. I was looking for taps first.
Besides, I have other projects where I could use small left hand taps in another industry that I’m involved in.
The key is an extra long reach, one I haven’t found anywhere.
It’s already been worked on and massacred as it is. I was going to fabricate a new one. My only hurdle is the left hand thread.
I guess I could cut off an available key and add an extension.
Thank you for your suggestions.
M.
Jerry Kieffer
May 31, 2005
2,976
580
wisconsin
M.
M.
Left Hand Taps and dies are readily available in singles from several sources, but you must first identify the size required.
A couple of examples are as follows
Taps Metric Left Hand - Minitaps
For sizes 1.7mm , 0-80 and up
High Speed Steel Metric Left Hand Taps
While unavailable micro taps are easily machined in either right or left, metric or inch, the key is to avoid carbon build up in very small threads during the hardening/tempering process that greatly decreases their efficiency. I can further discuss if need be.
Jerry Kieffer
karlmansson
Apr 20, 2013
2,804
203
Linköping, Sweden
M.
Figuring out the dimensions is probably a good first step. If it’s an oddball thread you may have more trouble finding that than the trouble you’ll have finding left handed ones. If you don’t have single point threading capabilities you could probably ask someone to help you out, if you end up having to make it that is.
Regards
Karl
Dushan Grujich
Jun 20, 2003
628
57
Bondi
geocities.ws
G'Day!
One of the places one can find replacement for the damaged key would be Rudolf Flume materials house in Germany. Have you stated the Swiza model perhaps I could have given You Flume's part number from their catalogue.
Cheers, Dushan
Reactions: DeweyC
167,052
1,455,737
87,272
zmuzaffarov
