Hi
I introduce myself. I'm just curious in general. My hobby is mainly 3D design and 3D printing. I started to get interested in gearing with this escape wheel model on thingiverse. then I started to get interested in the clock movement and in order to learn and understand, I decided to make a swiss escapement design myself!
I am still to understand the ratio of gears and the relationship with the force which actuates it. I want to make my design with a spring. And I will focus on the seconds and minutes only because I realize that I could not make a clock that will run for hours with a spring printed in 3D. If I can design a simple timer I will be happy!
To date I have succeeded in making an swiss escape wheel model in my software (fusion 360) and now working on the gears.
But I realize while reading that I will have to start by designing the motor spring and figuring out the force that I can generate and then derive the rations to arrive at the escape wheel.
Anyway, I'm learning and your forum seems like the perfect resource place to check when I'll get stuck.
BTW: I'm also trying to make it as small as possible taking the resolution of the printer in account
I'm at 0.8mm teeth gear right now, so the all clock could be in a 140mm X 140mm x
box.
