In the following thread with posts 51-61 there has been a discussion concluding as of today with my posting of the weight. This weight is lead that is wood encased and has corroded to the point that the wood has split.
mb.nawcc.org
Upon removing the outer portion of the wood encased lead pendulum what is shown is the significant corrosion. Now I understand that it is somewhat dangerous to inhale/injest the corroded material and I will be utilizing an industrial mask to do what is needed.
What are your suggestions as to what I might do to remedy the situation? If I cannot find anything I may have to resort to opening the bottom and replacing the weight.
Thanks,
Dick
The clocks of Charles Alvah Smith
The pallet assembly (Red Arrow) is mounted on a steel pin projecting forward from the back plate. The brass screw serves as a stop to keep the assembly from moving forward and helps to keep the escape wheel centered on the pallets (brass rollers). If your clock was running then this never needs...
Thanks,
Dick
