Rob P.
I'm on the hunt for a lathe because the Southbend Heavy 10 I've been using is way too big for most watch stuff. Plus the runout is more than is acceptable when working ultra small. But I LIKE the fact that there isn't anything I can throw at it that it can't hog it's way through like butter. For heavy work this thing's a beast that can't be beaten yet for fine work it leaves a bit to be desired.
So, I'm looking and looking and looking and I'm now in a dilemma.
Do I get a watchmakers/jewelers lathe or a micro lathe like a Unimat?
I like the Unimat because I'm used to a cross-slide setup. Plus, the Unimat can be converted to a simplistic micro-mill. Which would be great for precision drilling and milling flats and (maybe) gear teeth.
But...
A watchmakers lathe seems to offer more versatility and flexibility due to the more open design. I would also suspect that the tolerances are tighter. The fact that I'd have to learn to use a graver is a bit intimidating. However, I can get a cross-slide (bulky looking) but there's no milling capability.
My mission for the lathe is to mostly do repairs on clocks and watches. I would need to be able to manufacture small parts but would also like to be able to reconfigure existing parts as needed to fabricate custom stuff.
So, I'm left wondering, which do you think is a better fit for my needs?
But...
