Lanshire Motor
Discussion in 'Electric Horology' started by Ed Schmitt, Sep 7, 2013.
  1. Ed Schmitt
    Ed Schmitt Registered User
    Aug 30, 2003
    368
    CRNA retired
    Towanda, PA
    Have a customer bring in an electric clock. It is a "Lanshire Type SS-2" electric movement. I really don't work on electric clocks, so I'm looking to replace this movement, or for someone who can fix it. I figure that the coil is bad as I can not get any continuity readings by touching the electric wires going to the movement. Any help or advice is really appreciated.
    Ed Schmitt
    Shadows of Times Past
  2. skruft
    skruft Registered User
    Aug 5, 2002
    284
    I believe Lanshire is one of the few motors still being made and available, but I'm not sure which one you have. Post a photo and people here will help you.
  3. Ed Schmitt
    Aug 30, 2003
    368
    CRNA retired
    Towanda, PA
    Skruft
    As indicated the Lanshire is marked as "Type SS-2". I hope these pictures come through. Need repaired or replaced.
    Ed
  4. eskmill
    eskmill Registered User
    NAWCC Member Donor
    Aug 24, 2000
    7,139
    14
    Ed. The Lanshire SS-2 AC electric clock motor assembly has been obsolete for many years.
    Your photos suggest that it was a "fit-up" movement. There is a large selection of "fit-up" AC electric clock motors you could use as a replacement.
    The main issue is assuring that the old hands will properly fit on the replacement motor assembly.
  5. Elmo Electric
    Elmo Electric Registered User
    Jul 26, 2016
    17
    IT Consultant
    Atlanta GA
    Hi, did you ever get a repair / replacement?
Similar Threads - Lanshire Motor Forum Date
Lanshire reoconstruction Electric Horology Apr 24, 2016
Lanshire Type SS-2 Coil Needed Electric Horology Dec 1, 2014
Lanshire Running Backwards Electric Horology May 18, 2014
Could use some help with this Lanshire electric motor Electric Horology Mar 26, 2014
Lanshire EHPM Movement & XL7 clock motor Electric Horology May 2, 2013
