Ladies Elgin JWC Co 15 jewel pocket watch
Discussion in 'American Pocket Watches' started by bnewcol, Nov 18, 2012.
  1. bnewcol
    bnewcol New Member
    Nov 18, 2012
    I have a ladies pocket watch, gold in color, excellent condition, runs perfectly, not sure on the size, it looks about the size of a half dollar, about 1 3/16" diameter. It is clearly stamped J.W.C. Co on the inside, "warranted 25 years, crescent" with the # 202017236 on the inside of the cover. The workings are marked Elgin, 15 jewels, 16676692. It is not roman numerals, standard numbers, with a second hand circle where the 6 is. I am wondering about what year this is from? Thank you.
  2. Kevin W.
    Kevin W. Registered User
    21,998
    268
    I found this on your watch, it is a zero size, a womens watch.
    Grade:355
    Jewels:15
    Year:1912
    Class:117
    Model:3
    Named for:None
    Description:Elgin serial number 16676692, grade 355, 0 size, 15 jewels, made about 1912.
    Open faced movement. Pendent wind and set. Three-quarter plate.
    Rate:18,000 bph
  3. Kent
    Kent Registered User
    Gibbs Literary Award NAWCC Fellow NAWCC Silver Member
    Aug 26, 2000
    18,331
    1,585
    Hi bnewcol:
    Welcome to the NAWCC American Pocket Watch Message Board!
    Your watch case is gold-filled and I suspect that you misread the case marking. It sounds like it is was made by C.W.C.Co., the Crescent Watch Case Co.
    Unless you know that it has been cleaned and oiled within the last few years, you should have the watch serviced before running it very much. It may be helpful for you to read the Encyclopedia article on Watch Service and its related links, especially the one to the message board thread on the subject. The Encyclopedia article on Choosing a Pocket Watch Repair Person may be useful as well.
    Please feel free to ask about anything that isn't clear to you.
    Good luck,
  4. bnewcol
    bnewcol New Member
    Nov 18, 2012
    Hello
    Thank you for the reply. I did not misread the case marking, as the watch is in pristine condition, it is very clear, and it is J.W.C. Thank you for the repair info, I will get it serviced.
  5. bnewcol
    bnewcol New Member
    Nov 18, 2012
    Thank you so much Veritas for the information! How did you find it?
  6. bnewcol
    bnewcol New Member
    Nov 18, 2012
    Does anyone know a good pocketwatch repair person in Ventura County, CA?
  7. Kent
    Aug 26, 2000
    18,331
    1,585
    You can check the References section of the Elgin Watch Co. Encyclopedia article.
    Good luck,
