When restoring 400 day clocks what is the expert view on re-lacquering the brass, after full strip down and rebuild?
Hi, oldticker, what part of the UK are you from?oldticker said:I would do it because it preserves the finish.
Some people like a 'patina' look.
others would leave them unlacquered.
personal preference.
I have clocks going on 10 years with the high carnauba wax finish that still look very good. All of these have three coats of wax, well dried and buffed between coats.veritas said:Les , wax with high carnuba content works not bad too.I have one anniversary clock done that way and 6 months later still looks not bad.![]()
Not many clocks have wheels lacquered. New carriage clocks have barrels lacquered.Tim said:Harold,
Where do you get that special lacquer that bonds to brass? Is it also possible to brush it on and still have the same long lasting protection?
What about the wheels/barrel... same treatment?
Tim
Never tried wax to be honest - Does it keep the shine like lacquer ?pastimes said:I have clocks going on 10 years with the high carnauba wax finish that still look very good. All of these have three coats of wax, well dried and buffed between coats.veritas said:Les , wax with high carnuba content works not bad too.I have one anniversary clock done that way and 6 months later still looks not bad.![]()
John Hubby
i'm East Glos. nearly Oxford/Wilts, don't seem to have many UK posters on NAWCC!oldticker said:West Midlands.Hi, oldticker, what part of the UK are you from?
The finish using wax is initially very slightly "softer" than when using lacquer, like a very slight matte finish. However, after sitting on the shelf a couple of months it is difficult to see the difference. In my experience dust doesn't stick to the wax finish as tight as it does on lacquer. Aside from that, when you dust with a soft cotton cloth the wax tends to shine up some.oldticker said:Never tried wax to be honest - Does it keep the shine like lacquer ?
Assume this like car wax - keeps a lustre?
Tim T,Tim said:Harold,
Tim
