• Upcoming updates
Lacquer for brass
Darrmann39
Dec 6, 2020
1,030
294
56
I've had a few discussions about lacqureing brass. I've never had good luck. I've painted cars but brass is very tricky. So I didn't do it. I saw a guy post I believe on fb about Mohawk brass clear. I got some and I'm sold. The plates I wet sanded with 1500 grit and then 0000 steel wool and cleared. Wet sanded again and one final clear and they are pretty nice. Here's the base all done. And plates.
The orange peel is the worst and this was the best I've used
1663620779866861563462401021822.jpg 16636208145814095505515735101998.jpg 16636209021334387247399259184422.jpg
Darrmann39
Dec 6, 2020
1,030
294
56
View attachment 727214 View attachment 727221 View attachment 727222
It's not cheap. But look around I got it for $18 a can
Schatznut
Sep 26, 2020
1,425
741
SoCal
There have been a number of us that have recently discovered this product and we've all also had good luck with it. Sure beats spraying, stripping, spraying, stripping, swearing, spraying... with other lacquers.
Dells
Oct 18, 2019
1,039
320
In the cotswolds UK
I think you will find it was me on FB singing it’s praises, I used it on a Schatz 1000 day , I have been a coachbuilder all my life so am used to painting and although I didn’t have problems with auto lacquer I was never totally happy with the finish, it didn’t flow out like this especially formulated for brass does, I only give it one coat and it flows out beautifully, I am sold on it, the only problem now is I have 25 + clocks to do.
Dell
Edit no need to wet&dry just polish degrease and lacquer.
Schatznut
Sep 26, 2020
1,425
741
SoCal
It looks like you're using the lustre finish (M102-0450). I've been using the brilliant finish (M103-0500) and it is extremely high gloss...
Dells
Oct 18, 2019
1,039
320
In the cotswolds UK
I just use a light dust coat then a wetter coat immediately on top done, it flows out beautifully.
Dell
Reactions: Darrmann39
Schatznut
Sep 26, 2020
1,425
741
SoCal
Ditto what Dell said above. A dusting just to wet the surface slightly, then a light coat over that immediately. I didn't even have to polish it afterwards.
Dells
Oct 18, 2019
1,039
320
In the cotswolds UK
Flow’s out beautifully doesn’t it and it doesn’t even look lacquered.
Schatznut
Sep 26, 2020
1,425
741
SoCal
Yes, definitely. It's the "doesn't even look lacquered" look I've been trying to achieve for so long.
Schatznut
Sep 26, 2020
1,425
741
SoCal
Darrmann, before you strip the finish you've got, why don't you try just putting a coat of the gloss lacquer over the matte finish you've already put down? Worth a try?
GRZESIEK
Apr 3, 2017
32
12
It paint brass with colorless varnish used for cars. After adding the hardener to the varnish, it adds 100% solvent
The clock in the middle and on the right is painted a few months ago.
Regaeds
Darrmann39
Dec 6, 2020
1,030
294
56
Regaeds
I've never heard of varnish on cars and I've been painting all my life. Can you clarify what it is your talking about.
KurtinSA
Nov 24, 2014
5,748
587
San Antonio, TX
With all the car restoration shows I watch, they always talk about layers of "clear" which is what they put on over the color. Lots of hand buffing and color sanding going on. Always amazes me.
Kurt
Reactions: Darrmann39 and PatH
Darrmann39
Dec 6, 2020
1,030
294
56
Interesting clocks you have there!
Hmm weird question but my family business was a collision shop. Painted many cars. My trade was custom finish carpenter where I've heard lots about varnish now I repair and restore clocks. But can you just show me the product ?
GRZESIEK
Apr 3, 2017
32
12
Clears De Beer, Glasurit, Sikkens and many other companies- search on Googl You paint cars and you don't know what you need to use for painting. How do you paint metallic colors- base and clear (colorless varnish)
Darrmann39
Dec 6, 2020
1,030
294
56
How many cars have you painted in your life
Darrmann39
Dec 6, 2020
1,030
294
56
What country do you live in? Maybe that's the problem.
Dells
Oct 18, 2019
1,039
320
In the cotswolds UK
I think he means clear lacquer but if he is using 2K as I think he is because he is adding hardener , not ideal for home use because it’s isocyanate and will definitely need paint stripper to remove next time.
He definitely has some nice clock though.
GRZESIEK
Apr 3, 2017
32
12
Of course you are right, you can't do it at home.
It is a professional product, applied using spray gun.
I only wrote how I do it, maybe someone has such a possibility too.
marylander
Sep 9, 2008
941
73
Maryland
This is what I use for all my 400-day clocks. You can purchase it from Walmart. I polished and lacquered 90% of my brass clocks. They do not require polish job again.
Ming
Schatznut
Sep 26, 2020
1,425
741
SoCal
Ming
Does it flow out well for you? This is what I was using with unsatisfactory results before I discovered the Mohawk brass lacquer. I couldn't tell if it was the material or my technique that was leading to a poor outcome. I *assumed* it was the Rustoleum lacquer that was the problem and *thought* my technique was OK, and *thought* I'd validated it when I got spectacular results with the Mohawk product on the first try.
marylander
Sep 9, 2008
941
73
Maryland
It worked for me. There were no flowing problem. I guess that practice is the key to get good result. I can see the improvement of my work. Maybe, we do not have same perception of satisfactory result. If Mohawk woks for you, keep using it. I have never tried any other lacquers since Rustorleum lacquer work well for me. When humidity is low, I spread the parts. When humidity is high, I used hair blower to warm the parts before spread. I did not do every time successfully, sometimes, I have to use lacquer thinner to wipe off what I just did to redo.
Ming
Darrmann39
Dec 6, 2020
1,030
294
56
I'm torn now between leaving this mirror finish and using my new ultra gloss Mohawk.
20220926_173641.jpg 20220926_173645.jpg 20220926_175525.jpg 20220926_175530.jpg
Ken M
Feb 28, 2009
2,020
187
Holiday, FL
I have one of those, I try not to use it. That Jewelers Rouge, the white and black stuff gets everywhere. It does wonders for brass, but after my first week with it using it all the time, everything in my shop was red. My cat had red paws, couldn't figure it out. Then I saw my floor and everything else was red.
Reactions: gmorse
Darrmann39
Dec 6, 2020
1,030
294
56
Best finish I've ever had. So I'd say whatever it takes
Reactions: Ken M
Darrmann39
Dec 6, 2020
1,030
294
56
If you have never heard of Renaissance wax here's what a good polish with polishing wheel and then wax with Renaissance.
Reactions: Ken M
Schatznut
Sep 26, 2020
1,425
741
SoCal
Echoing what Ken says. I've been trying to get the perfect "it doesn't look like it's lacquered" lacquer finish on the parts that face the elements - bases and cases. For the parts that are always enclosed, I use Renaissance wax and it works great. For polishing, I use a soft cotton muslin wheel on my bench grinder, and plain old car polish. Requires a bit of patience but gives a beautiful shine. Now with a coat of clear lacquer on it, I can sleep better at night.
Dells
Oct 18, 2019
1,039
320
In the cotswolds UK
Echo what Schatznut said with that shine then Mohawk lacquer you won’t notice much difference.
Ken M
Feb 28, 2009
2,020
187
Holiday, FL
I have Mohawk and Nikolas Gold tint. I much prefer Nikolas. I'll need to get some clear, but the gold is really nice.
Dells
Oct 18, 2019
1,039
320
In the cotswolds UK
That’s okay if you live in USA but in uk we can only get Mohawk and I am that happy with it I am expecting 4 more to be delivered tomorrow.
Reactions: Ken M
MartinM
Jun 24, 2011
3,134
129
El Dorado, CA
The gold tint is great for those times when the maker originally used such a lacquer, such as Schatz' Mariner front bezels or when you need to correct for originally brass plated parts having lost their plating.
179,016
1,570,212
54,047
aztrukin
909
3,088
Swiss Fake by Kent
