Kundo suspension spring length
Jeff C
NAWCC Business
May 26, 2005
2,123
Seven Fields, Pennsylvania
Hello, I picked this Kundo up at a local flea market and it needs the spring. I have the correct springs for this I just wondered to avoid cutting it too long or short before I put it in the blocks what would be the length to cut it too? Also would I be wrong in guessing this is from the late 60's or early 70's? It does have a plastic spring guard.
Jeff C
NAWCC Business
May 26, 2005
2,123
Joe Collins
Jan 3, 2004
986
Hi Jeff,
I can't see enough detail to date your clock but I can tell you the length of the suspension unit.
The length between the upper and lower block pins is 127mm. (4.999") The fork is 7mm below the top block. (.275")
Hope this helps,
Joe
166,298
1,448,976
86,803
Costin
2,910
