I have replaced the badly twisted suspension spring on my Kundo Standard with a Horolovar replacement. I ordered a 3A assembly, which was supposedly the right one, and I ordered some extra .0032 springs just in case. The 3A was 1/4 inch too long and the blocks were not a perfect match. The spring on the 3A was noticeably wider than the individual .0032 springs. I decided to build a new assembly with my old blocks, using one of the new springs. I had to trim aprx 3/8 inch to keep from dragging on the bottom of the cup. ..........It now keeps perfect time with 20 to 30 degrees overswing after the clicks, both sides. HOWEVER, total rotation is only 180 degrees. I think I remember reading somewhere that there should be 270 to 300 degrees of rotation. Have I done something wrong?? Is it just a coincidence that it's keeping good time?? John
