• Upcoming updates
Kundo pendulum weights - again
AndyDWA
Dec 26, 2013
621
Western Australia
I recently purchased a square-dial Kundo standard for my mother-in-law and set about cleaning it up. I had to "straighten" the anchor pin to get it going but could barely get 180deg turn out of it.
The pendulum only weighed in at ~240g (~8.5oz), which I understand is at the low end of Kundo weights, as described by John Hubby. With this in mind, I attached a .0024" wire (I didn't have anything closer to .0025"). It now rotates 270deg, but the clock runs 50% slow. It takes 1.5 minutes (90 seconds) to complete 8 beats.
I assume, since I need to gain around 30 minutes per hour, that would mean: 30mins/4mins => .00075" extra thickness.
This would mean fitting the recommended .0032" to correct the rate but I assumed the book was incorrect, from earlier commentary.
Also, the weights are molded lead (soft), not steel. Have I weighed it wrong or is there something else I'm missing? (I should have weighed some of my others but hate messing with them when they're running)
I am also interested in some indication of date. The backplate features two holes to the lower and left of the winding arbor (they look like leftovers from external click models) and an isolated logo. I think it's plate 1389. It has the common pendulum lock, so I guess it's post-1954ish. Do the two holes make it older than my other, almost-identical, clock that doesn't feature those holes?
Thanks as always.
49,469
2,925
I've found that .0032" works for most Kundo's. Your math is correct. Go for it.
KurtinSA
Nov 24, 2014
5,734
586
San Antonio, TX
I recently acquired a square-dialed standard sized Kundo. The pendulum weighed 8oz which I believe is essentially the correct weight. I was on the phone with Chris Nimon at The Horolovar Store a while back and we were discussing pendulums weights for a clock I was working on. He noted weights from some of the pendulums in the guide - #97 @ 7.8oz, #99 @ 7.9oz, #100 @ 8.1oz, #102 ranges from 7.3 to 7.8oz...these were weights that he had measured himself. I would say that 8.5oz is too heavy.
Kurt
AndyDWA
Dec 26, 2013
621
Western Australia
Is that weights in the pendulum, or weights from the pendulum?
Even so, my figure would not have been accurate to the decimal point. I think I rounded up a little from what the scales actually said and was referencing another comment thread where three different weights were mentioned, with 8.5 being the lowest.
Still, at .0032", it lands right on the book recommendation so I'll probably swap the spring and see what happens.
Thanks.
KurtinSA
Nov 24, 2014
5,734
586
San Antonio, TX
I weighed the entire pendulum...unhooked from the lower block and put that on the scale. I bought a postal scale at the local store...says it's accurate to 0.1oz.
Kurt
178,855
1,568,747
54,001
Tracy K
909
3,078
E. Howard & Co. by Steven Thornberry
