Kundo Miniature wont go
Billingd
Sep 9, 2017
17
Hi
Recently bought an old Kundo miniature. I have replaced the broken suspension spring and put the clock in beat. Clock runs for a few minutes but the pendulum does not gain any rotational power. After a few minutes, the clock stops. I have adjusted the gap in the fork to accept a piece of paper (it was too tight), and also moved the fork progressively down the suspension wire without any improvement in performance. However, when I manually rock the verge and anchor, the escape wheel rotates as it should, and I've tried this for several minutes. I'm thinking I need to strip and clean the movement but I'm confused as why the escape wheel rotates ok with no signs of any sticking. Just wondering if there's anything else I should be trying prior to a strip and clean ?
Many thanks
David
KurtinSA
Nov 24, 2014
4,309
254
San Antonio, TX
David -
How long is a "few minutes"? Also, does the escape wheel really "snap" or move with authority when it unlocks? If it just moves but doesn't do it quickly, that suggests there's little power being transferred to the suspension spring.
Likely, if you look inside the movement and see bits of fuzz, lint, etc., it probably really means that it has to come apart for cleaning.
Kurt
Billingd
Sep 9, 2017
17
Hi Kurt
In this case a few minutes is less than 5. I’ve put other 400 day clocks in beat before that will build up their rotational energy from the merest push to the first escape wheel movement. With this one it just gets slower and slower from when you first let it go until it stops less than 5 mins later. I can’t tell how much authority the EW has. Clearly it cant be enough, so I’ll take it apart for a clean. It would be helpful to know what other people use to clean the components with once they’re apart. Some form of alcohol? Or are there better cleaners out there?
Cheers
David
KurtinSA
Nov 24, 2014
4,309
254
San Antonio, TX
David -
There are certainly a variety of cleaning systems/methods. The ultimate is an ultrasonic system. I've not gone that route, but for now, I'm using a diluted bath of Simple Green and scrub parts after they soak for 15-20 minutes. I then blow dry. The one thing that put me up another level of success is use of a jeweler's lathe to polish the pivots. Also important to peg the holes. You can start with half of a toothpick chucked up in a Dremel.
Next time you reassemble, put the going train (that's the stuff between the plates) in except leave out the anchor. Then begin to wind the mainspring. It's been suggested that if the escape wheel will start off running or moving with as little as 2 clicks, you likely won't have any friction problems. Then you can proceed with other checks. Another check that I read about recently is to add to this first check by including the motion works or the gears and hands on the front of the plate. Repeat the click test. It probably will take another click to get the hands to move. But if any of this takes 4-5 or more clicks, you have a binding problem.
In your case, before disassembling, try taking off the motion works. Does the clock now run? If the clock is stopping in 5 minutes, seems like you have a serious drag somewhere.
Kurt
Billingd
Sep 9, 2017
17
Kurt
Took off the clock face, fingers and gears behind. Still stops after 3-4 minutes. So that doesn’t appear to be the issue. Have noticed that as the EW moves, ticking is almost inaudible. So maybe a sign of little strength / power in the movement. Will investigate further.
Thanks for the advice
David
KurtinSA
Nov 24, 2014
4,309
254
San Antonio, TX
Yeah, you should be able to hear more of an audible "snap"...although on the smaller clocks with less power, it might be quieter.
Kurt
tracerjack
Jun 6, 2016
1,666
236
Lodi, CA
I learned early on from this very forum that the mainsprings for these clocks must run smoothly or the clock will stop, and they need oil, not grease. I think I used grease on the first mainspring I cleaned, and despite everything being fine, the clock does not perform well. Stops, then works, stops again. Will be redoing that one soon. As old as these clocks are, and probably never having been cleaned, I am now to the point that the first thing I do is tear them down and clean the mainspring. So far, out of twelve, I think I have only found one that wasn't dry.
Billingd
Sep 9, 2017
17
And she’s going Following a strip down and clean, now all back together with a 270 + swing and healthy overswing. Nothing majorly wrong but she had a lot of old oil. So must have been like wading through treacle beforehand.
Thanks for the support and encouragement
David
165,444
1,440,174
86,232
Vicepa
2,873
