Kundo Minature Project
Discussion in '400-Day & Atmos' started by Les Sanders, Dec 27, 2019.
  1. Les Sanders
    Les Sanders Registered User
    Apr 3, 2010
    703
    19
    Clock Repairman
    Sahuarita Arizona
    My wife picked up 5 400 day clocks and said here, fix em. LOL! So # 1 will be a Kundo Minature Disassemble clean polish oil new suspension, you guys know the drill. I need advice on the Plastic Dome, has a number of scratches marring I have not had much luck with them any one have a method of polishing these domes?
  2. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,034
    95
    El Dorado, CA
    It really just takes patience and a lot of careful polishing with various sandpaper grits & polishing compound and if you want the best finish, a good sealer. I find a product called, "Blue Magic" to work well for a decent price.
    Most of the headlight restoration kits out there have everything you need. If you opt for one of the options that use a power drill, make sure to go easy and keep the surface wet, during the polishing phase. For this project, I''d start with the finest grit sandpaper and see how it goes, only getting more aggressive if necessary.
  3. Wayne A
    Wayne A Registered User
    Sep 24, 2019
    191
    34
    Retired, process controll systems
    If the scratching is not severe on the plastic dome, car wax does an excellent job on making them clearer than glass. I like Meguiars gold class carnauba wax, which also works well on your cars.
  4. Les Sanders
    Apr 3, 2010
    703
    19
    Clock Repairman
    Sahuarita Arizona
    I have Carnauba wax and also Renaissance Wax I will start there and report back.
  5. Wayne A
    Sep 24, 2019
    191
    34
    The car wax has a mild abrasive in it so I'm not sure if a pure wax will have the same results. Worth a try though. This Kern I recently went through had a fogged dome, here it is after waxing.
  6. sjaffe
    sjaffe Registered User
    Dec 25, 2012
    419
    Engineer
    Santa Rosa,CA
    Hi Les,
    I have had good luck with Novus plastic polishing compounds. I apply with a cotton cloth (t-shirt) by hand. Simple, inexpensive, effective.
    Stan
