New member here and need some help.
I have completely disassembled a Kundo minature back plate 1406J, cleaned, installed new main spring, put back together, oiled all pivots, and installed new suspension wire.
Prior to disassembly took a lot of photographs with my Ipad, to ensure it was put together correctly, plus I had an identical parts clock for reference.
Once it was reassembled I moved the anchor pin manually and observed that all the gears were turning.
The first time I attached a new suspension spring the pendulum would not turn, I put a small kink in it, so I then replaced it.
The pendulum now rotates well. It was rewound.
Now I find that the pendulum rotates well, but does not the anchor pin. I took off the pendulum and suspension spring a number of times and again manually moved the anchor pin to observe the gears working and no binding, it moves very easily and you can see the escapment wheel engaging and moving as well as the other smaller gears. But as soon as the suspension spring and pendulum are attached (no binding) and rotates it fails to move the anchor pin. What am I doing wrong? I have 400 day clock repair manual and have read it a number of times to figure out my problem without any success.
Any suggestions would be appreciated. Thanks.
