A midget Kundo that I have just overhauled is running well, except even after the regulating nut has been turned to full slow (anti-clockwise adjustment),it is still gaining about 30 minutes in 12 hours. It is fitted with the 5F Horolovar s/s .022' as per the Guide. I suppose I will have to thin down the SS. I am wondering if this is normal. The pivots, holes etc are all shining, with the correct side movement etc.. I have adjusted the overswing and the clcok is in beat but is only giving 5 BPM. The clock runs perfect with no sticking when the anchor unit is removed and the clock wound 1/2 turn.
The following SHOUT is for help.
