I was looking at one my Kundos and wondered how would you remove the dial assembly from the from the front movement plate? This is one of the post war units that have a stud of some type coming from the dial pan through the front plate then making a twist of some sort to lock it on. This is not one of the Kundos that use pins. Looks like you would twist this stud but knowing me I would snap it off or crack the dial.
Thanks for your advice,
