• Upcoming updates
Kundo clockface removal
Billingd
Sep 9, 2017
17
Hi
My first post on this forum. I wonder if you can help me ? I have recently bought an old Kundo anniversary clock and would like to oil the front pivot holes behind the clock face. I cant work out how to remove the face. Maybe it doesn't remove ? I have attached an image of what looks like a brass fastener inside the clock which holds the face on. Its highlighted in the red circle. It looks like it should just twist 90 degrees and then allow exit through the brass plate. But they all seem stubbornly rigid. And there are 3 of them around the face.
Just wondering if anyone has been here before on this type of clock and has any advice?
Tried oiling the pivots inside the clock, but can't reach some of them.
KurtinSA
Nov 24, 2014
5,846
619
San Antonio, TX
Welcome to the message board! I've worked on several clocks with this type of fastener. You are correct that small block needs to turn 90 degrees...I believe it will turn either direction. Some of them are oriented to allow you to come in parallel to the long faces of the block...better leverage that way. Work on the ones that afford better access. If you can get one or two of them undone, that might help with the stubborn last one will poor access...at least the dial will move/flex a bit maybe relieving some tension.
If you were headed for a complete teardown, I would probably just disassemble the clock with the dial in place...I don't think there's anything captive on the back plate. Once you get the plate off and the internal motion works, you have plenty of room to get at those dial fasteners.
Kurt
Billingd
Sep 9, 2017
17
Hi Kurt
Many thanks for confirming. I've been trying to use a small pair of long nose pliers but keeping a grip on these small brass blocks is proving challenging. Any suggestions for a more suitable tool in your experience?
Thanks again
David
Burkhard Rasch
Jun 1, 2007
5,220
406
66
Twistringen
get hold of a surgical needle holder,they´re strong and hold firmly,and they´re small enough to fit between the plates and the wheels.They come in different sizes.
Burkhard
KurtinSA
Nov 24, 2014
5,846
619
San Antonio, TX
I was going to suggest a needle nose pliers where the nose is bent 90 degrees. My only concern would be the serrations in the pliers and what it might do to the brass. Try to find something that mar it.
Here's a thought...can you find a small open-end wrench that will fit...maybe you can use a caliper to measure across the thin dimension. Then put that wrench on the dial fitting, then use your needle nose on the wrench. That keeps the serrations off of the brass.
Kurt
Billingd
Sep 9, 2017
17
Great ideas! Thanks for your helpful advice. I'm away from home for a few days but will try these out when I get back
Many thanks
David
Ally
May 30, 2014
21
Hi. The best way IS a small good quality wrench on the hexagon rather than the locking bar. Works every time.
Good luck
Ally
marylander
Sep 9, 2008
944
76
Maryland
David, I normally let down the main spring and take the back plate and the wheels off to remove the dial in this situation. It may be time saving to do so if you do not have a tool to turn the dial lock.
Ming
180,087
1,571,001
54,369
wbaNev
911
3,097
Philadelphia Watch Case Co. by Kent
