Raymond101
- Jun 25, 2022
- 395
- 96
- 28
- 70
- Country
Hi I a got a early kundo electronic clock as everyone knows someone had attempted a repair. Got it cheap in really bad condition.
So I decided it needs a TLC and would be a fun project. I have watched many videos of these clocks and they all seem to have what I call a fish tail swing. After entirely stripping it down & cleaning. The suspension spring was totally destroyed. I made a new 1 from a pattern of the original. With the T shape top bar and double leafs 0.03 .
This I found oscillatored from the coil pulses . So I remade it just a straight flex . BTW I buy 1mt roll of stainless springsteel foil 0.03 good for a thousands of suspension springs
This would keep good time but also had fish tail effect.
So I decided to make a damping copper ring in the coil .left side . This is the single wound coil type 2000mh , 3100ohm . & single magnet. And it had been opened before. So after fitting the copper damping ring. The pendulum rode now swing perfectly symmetrical to center.
The original electronic board just need cleaning as all the components were still within 1% tolerance, amazingly.
Put an oscilloscope on the coil pulse and took a second reading from end of swing with IR sensor. To see if there was any losses in the suspension spring vs power. Very happy the drift different was less than u /sec.
So thought this might help others with this type of clock .
1 beat pulse = 1.5s .. (1.5hz)
90 beats Per minute
5400 BPH .
90 beats Per minute
5400 BPH .
