kundo clock Suspension Spring
Burkhard Rasch
Jun 1, 2007
4,946
214
65
Twistringen
sorry I don't have my reference book at hand,but if the moderators could move the thread to the torsion clock forum I´m sure someone here will be able to help.Thanks
Burkhard
KurtinSA
Nov 24, 2014
4,508
294
San Antonio, TX
I have a clock just like this waiting for cleaning. The back plate is 1406H from the repair guide. The spring thickness is 0.0023". I weighed my pendulum and it was 5.6oz.
Kurt
46,937
1,994
I've moved this to the 400 day forum. I believe KurtinSA has provided the needed information.
bummer666
May 13, 2014
thank you very much kurt!! but do you know the length? or is the 0.0023" standard for this kundo clock?
KurtinSA
Nov 24, 2014
4,508
294
San Antonio, TX
This is where you need to get a copy of the Terwilliger repair guide if you plan on being involved in these types of clocks. It shows the specific back plate as well as what the suspension spring looks like. The guide references #5E...a photo is attached. The distance between the two blocks is about 76mm but it has to be slightly longer than that to fit inside the upper and lower blocks. The fork is about 3.5mm below the top block, but this distance can change as you begin to set the spring and clock up.
Kurt
bummer666
May 13, 2014
"HELP" kundo oval clock Suspension Spring instructions
hello once again forum
I need help once again, I'm having big time trouble installing my new suspension spring I got for my Kundo Oval. I've already broken one!!!
:mad: Mallet :confused::confused::confused: does any one have step by step with picture instruction guide?:?| I don't know what I'm doing and I looked on the web and got nothing :bang:
thank you again forum!!! :D
KurtinSA
Nov 24, 2014
4,508
294
San Antonio, TX
Re: "HELP" kundo oval clock Suspension Spring instructions
Mods, maybe this can be combined with the posters original thread...keep this all together??
So, how did the spring break? And I don't think there's a picture illustration out there for this.
Question...are you looking to get more involved in 400-day clocks or will this be your only one? The Horolovar Company sells complete suspension units ready to install in the clock. When I first started on these types of clocks, I bought complete units. Then I built up enough "courage" and tools to decide that I could unscrew each block and fork, cut a new spring to the right length, and reassemble. You need good vision (I use a visor with magnifiers) and tools to firmly hold the blocks and unscrew the small fasteners without messing things up.
This particular Kundo, and most that I have, have an unusual arrangement for fitting the bottom block to the pendulum. They just don't fit over a mating hook. The bottom block has a removable pin. You have to have 3-4 hands to fit the bottom block because the spring system on the pendulum must be held out of the way while the pin is slid out. It was difficult the first time, but I've gotten better at it.
Kurt
MartinM
Jun 24, 2011
3,091
El Dorado, CA
I find it easiest, on this model, to build the suspension spring assembly and then install it on the pendulum, first.
Then, carefully install the pendulum on the clock and lock it into place.
Lastly, and being careful not to mess up the area of the spring between the top block and the fork, install the top block in its hanger.
If you have the fork with a closed end, this method can still work, but it is a challenge.
46,937
1,994
For putting the blocks on, drill a small hole into a piece of wood to insert the pin into while you work with the screws. It's much easier.
Reactions: turboflyer
MartinM
Jun 24, 2011
3,091
El Dorado, CA
This one doesn't have a pin except when actually attached to the pendulum.
You have to pull the pin out in order to free the lower block from the pendulum.
KurtinSA
Nov 24, 2014
4,508
294
San Antonio, TX
The first Kundo I got with this arrangement, the pin just fell out. Others have the pin "staked" in...by that I mean the middle of the pin was knurled so that it was quasi-stuck in hole in the block. Personally, I don't like it being that stuck, so I filed the middle of the pin down so it's not so difficult to get in/out.
Kurt
MartinM
Jun 24, 2011
3,091
El Dorado, CA
I've found that you can have a 'best of both worlds" scenario by repeatedly inserting the pin into the lower block while the suspension is off the pendulum. It only takes a few times doing this while rotating the pin, slightly, to get the fitment where there is still slight resistance to inserting/removing the pin and it can't accidentally fall out, should the retaining collar be lifted or caught on something.
I used to file it down or replace it with a bespoke pin, but I found that it's actually harder to work with a pin that floats completely free.
Doing this also preserves the complete originality of the clock (Should these ever actually be worth anything).
bummer666
May 13, 2014
Thank you all so much!! :thumb: I finally got spring on but know I cant get clock working it works for about 15/20 mins. and stops. I adjusted disk in both directions on pendulum but still same thing I leveled clock also am I doing some thing wrong??exhausted
harold bain
40,853
179
73
It is likely out of beat. The pendulum should go an equal distance in each direction past where the escapement moves.
46,937
1,994
Agreed. Another possibility is that you don't have enough over swing. You can increase that by lowering the fork a little.
KurtinSA
Nov 24, 2014
4,508
294
San Antonio, TX
If the simple adjustments don't let the clock start working, then the next step is to take the clock apart for proper servicing. From the initial post, it's hard to tell what the state of the clock is or what has been done to it. Whenever I get a new-to-me clock, I try all the things being suggested. If no amount of adjustments get the clock to work, it goes onto the shelf where it awaits teardown.
Kurt
167,051
1,455,716
87,270
Ravens Watch
