Kundo clock help needed
turboflyer
Feb 17, 2016
224
40
Just finished doing a mild restoration on this Kundo. All apart, cleaned, spring serviced, back together. But I am not sure how to proceed getting the torsion spring off the pendulum. Looks simple enough. Don’t want to force the pin out. Is there another way?
8A22C300-FE80-4F1A-95E6-3BEDEF7640E8.jpeg CEC5EA4C-2B99-42C4-8B18-4210C1083A2B.jpeg
etmb61
Oct 25, 2010
2,859
295
Mascoutah, IL
Raise the collar against the spring to expose the steel pin that holds the block in the top of the pendulum. Tap the pin out with a punch. After that I usually file the crimp on the center of the pin to make it a loose fit so it will go back together without using a hammer.
Eric
Reactions: Wayne A
Phil G4SPZ
Oct 18, 2018
611
101
68
Bewdley, Worcestershire, UK
I did one this morning! The pin came out when squeezed firmly with pliers. I filed the pin and made it easier to replace.
Phil
Reactions: turboflyer
167,159
1,456,618
87,340
Jerrydodge
