I recently inherited a Kundo 9" anniversary clock that belonged to my parents. I never remember seeing it operating- it sat in my parents living room on a shelf when I was a child. My mothers sister remembers it and said my parents could "never get it to work". I want to get it operating as I remember it fondly from my childhood.
I have been reading the forum and researching these anniversary clocks. I am not a 'clock guy'. I do own and maintain a grandfather clock with an Urgos movement- and have learned how to operate, clean, and oil it. I am mechanically capable of doing whatever needs to be done, with guidance. I first tried to operate this anniversary clock as I found it. It winds fine, but following the suggestions on this site on getting it going, it would not sustain operation. Suspension system seems in reasonable condition- no kinks, everything is aligned well. Upon careful examination, the escapement aknowledgeable ng up' when it gets to a certain part of the rotation.
I decided a good cleaning was in order. I made a tool to let the mainspring down safely, and disassembled the movement. I cleaned and inspected all the pivots. Everything looks in good condition. I did not attempt to disassemble and clean the mainspring at this point, due to not having a winder, or being familiar with dealing with a mainspring. The winding action seems smooth, and the spring seems plenty strong, to my inexperieced hand. I inspected the escapement parts with a magnifier, I can see no damage, or anything unusual. I reassembled the movement, oiled all the pivots with triflow teflon lubricant applied with a toothpick. I read up on adjusting the beat, and have fiddled with it considerably. It still will not sustain running. I have raised & lowered the fork, checked the fork clearance to the anchor rod, to no avail.
I am not very experienced with escapements and their operation, but it appears to not have a 'clean' escapement action- like its dragging or scraping on part of the action. I have adjusted beat until I have a reasonable overrun, and the ticks are occurring pretty evenly. It just seems to not have enough power to keep running.
I have since read that cleaning & oiling the mainspring should be the first thing done with one of these clocks. I will build a spring winder and attempt to carry that out. However, it just seems to me it ought to run for a bit, even if the spring is gunked up. My aunts' comment that my parents could never get it to run tells me something is hinky with it- as my dad was an engineer and a very capable and knowledgeable man.
What should I be focusing on at this point? The mainspring? Logic tells me to rule that out, but if anyone has something I can try while researching how to handle that mainspring, I would appreciate it.
