Korean Clock Strike
Discussion in 'Clock Repair' started by chaplin37, Oct 12, 2017.
  1. chaplin37
    chaplin37 Registered User
    Dec 29, 2011
    66
    So I am having trouble with this regulator clock with a korean movement in it. I have included a link to the video i took of it. Im having trouble with the 30 min strike. The warning starts, it looks like it is going to strike but it is stopped by the locking lever. Any suggestions on how to trouble shoot this?
  2. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,867
    watchmaker
    Western NSW, Australia
    #2 roughbarked, Oct 12, 2017
    I'm not seeing your video but if it isn't a lift issue or a sticky rack, it would be a synchronising issue with the gathering pallet.
    Now that I have seen the video, it all seems to be working. There seems to be a long delay on the hammer lever action.
  3. leeinv66
    leeinv66 Super Moderator
    Donor NAWCC Member
    Mar 31, 2005
    8,000
    12
    Industry Specialist
    Launceston Tasmania
    Moving to clock repair.
  4. chaplin37
    Dec 29, 2011
    66
    It's not working correct on the 1/2 hour strike as it doesn't strike
  5. David S
    David S Registered User
    Donor NAWCC Member
    Dec 18, 2011
    5,797
    20
    Brockville, On Canada
    Can you post a pic of the complete movement so we can see all the levers etc.
    David
  6. chaplin37
    Dec 29, 2011
    66
    It also doesnt strike at 1 o'clock either
  7. chaplin37
    Dec 29, 2011
    66
    Here you go
  8. roughbarked
    Dec 2, 2016
    1,867
    watchmaker
    You need to have a look at the gong rod and track it back to the other end. It seems to function well on multiple strikes but not on single ones. It doesn't seem to be getting enough impulse off a single lift.
  9. shutterbug
    34,345
    30
    That bottom tooth on the rack should be shorter than the others. Yours looks a bit too long, and the rack can't drop past it for the 1/2 hour strike. It should not affect the 1:00 strike on the hour.
  10. chaplin37
    Dec 29, 2011
    66
    Figured it out had to move the star wheel. The only other problem is from hour 9 to 11 it is short one strike and this is why, the rack hook is falling onto the tooth for those hours and not in the middle of the tooth. From hours 12 to 8 it falls inbetween so how do I get hours 9 to 11 to do the same?
  11. shutterbug
    34,345
    30
    You will probably have to raise the snail and turn it one tooth clockwise.
  12. chaplin37
    Dec 29, 2011
    66
    Hi Shutterbug, Thank you and that was exactly what i was thinking about sitting down and thinking about it.
Similar Threads - Korean Clock Strike Forum Date
Korean Clock Click Clock Repair Tuesday at 11:45 AM
Mainspring for Korean clock Clock Repair Jan 21, 2017
Korean chalet style quartz cuckoo clock Clock Repair Sep 15, 2016
chimes for korean wall clock Clock Repair Apr 11, 2016
