Koma minature cracks
Discussion in '400-Day & Atmos' started by Wayne A, Jan 23, 2020.
  1. Wayne A
    Wayne A Registered User
    Sep 24, 2019
    264
    42
    Retired, process controll systems
    I've seen bases with cracks and splits but this clock takes it to a new level I had not seen. Base is almost faceted there's so many micro cracks in it. Curious as to how this could happen to the base.. Suspect metallurgy problem and stress from manufacturing.
    Otherwise its a nice looking clock. Anyone know of a polish that will not leave discolored residue in the tiny cracks?
    20200123_144556.jpg 20200123_144959.jpg 20200123_144853.jpg 20200123_144737.jpg
  2. victor miranda
    victor miranda Registered User
    Jan 13, 2017
    363
    42
    computer programming stuff
    Baltimore
    that is quite curious...
    I have read that ammonia will cause cracks in military brass
    (I believe clock brass is very similar)
    perhaps the clock base was soaked in ammonia to clean it?
    or that the cleaner stayed in the underside...
    victor
  3. Wayne A
    Sep 24, 2019
    264
    42
    Interesting point about chemical corrosion, just never thought washing would provide enough time for it to take place. Looking again at the base there is quite a large cavity that potentially could hold some fluid although the leveling feet threads probably would drain it eventually.
  4. Wayne A
    Sep 24, 2019
    264
    42
    Little reading and it does seem likely to be stress corrosion. Cracks are only in the bell of the base where there must have been higher stresses during manufacturing. I've seen plenty of chloride stress corrosion on stainless steel working at an oil refinery but nothing on brass. Although about the only place brass was used was pneumatic tubing fittings which turned black in some areas of the plant.
    Ammonia as a brass cleaner
    The Hendrix Group > Resources > Material Property Data > Copper and Copper Alloys > Brasses > SC Cracking
  5. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    3,577
    133
    Aerospace Engineer (Ret.)
    San Antonio, TX
    I can add to that from another area. In the 1950s and 1960s, brass was used to form the floats in BMW motorcycle carburetors. Over time, the brass would crack and take on fuel, converting the float to a sinker...that doesn't work too well in a carbs! It was even seen in floats which had been on the shelf unused. The stresses experienced during forming were residual in the material and would later crack.
    Kurt
  6. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,048
    100
    El Dorado, CA
    It's funny how some parts that appear to be minor stampings can end up overly work hardened while others that are really stressed in the manufacturing process are fine, years later. I have some brass tubes about 6 inched long and a half inch ID that look much like glass test tubes but, made of sheet brass and with fully rolled rims that are as solid as the day they were created.
  7. Wayne A
    Sep 24, 2019
    264
    42
    I'm guessing that thermal stress relieving was something that clock manufactures never used.
  8. Snapper
    Snapper Registered User
    Nov 30, 2014
    284
    Lincolnshire, UK
    I have seen this in many press formed oil fonts in some ships lamps. I consider it due to poor annealing prior to forming and subsequent failure to stree relieve.
  9. Wayne A
    Sep 24, 2019
    264
    42
    Well it cleaned up better than I expected for all the cracks.
    Had to set the front mounted eccentric, adjust both pallets and sand down a suspension spring because I did not have the right one on hand. Called for a .003 but I think ended up closer to .0028 to get it in range. It been running about a day and turning 350deg.
