It may have been given as a wedding present in 1968, but your Kienzle clock is much older than 1968.The seller said it’s from 1968 from a wedding
No - not rare.The finial is intact and complete which I suppose is kind of rare?
I always thought these finials are always lost, or removed.No - not rare.
A good deal. Since it was stripped, I don't think you'd harm the value of the clock if you try to match the stain to the original. Perhaps around 1910-1920.I only got it for 30. Should I stain it since it was stripped? How old is it? Could you tell with the numbers?
Was there supposed to be anything attached to the strike activation lever? Like string?
Thanks for the reply. Any idea what that fraction represents or that Roman numeral “II”?Perhaps around 1910-1920.
The Roman numeral most likely represents quality (Ie. "First quality" or "Second quality") that the Germans liked to label on some of their clocks. The fraction is pendulum length if memory serves correctly.Thanks for the reply. Any idea what that fraction represents or that Roman numeral “II”?
The trademark on your movement was registered in 1892, and was the first of the "Flügelrad" trademarks of Kienzle. I believe they had 4 total Flügelrad trademarks. The last of the Flügelrad trademarks was registered in 1923. I do not know if the various Kienzle trademarks overlapped, but if they did overlap, I assume it would not be for too many years.How old is it? Could you tell with the numbers?
No, they were not always lost.I always thought these finials are always lost, or removed.
I know Lenzkirch used this system and would not be surprised if Kienzle did also. Second quality in Lenzkirch jargon did not mean inferior quality, just that the pivots of the movements were not as polished as the first quality movements - things of this nature.The Roman numeral most likely represents quality (Ie. "First quality" or "Second quality") that the Germans liked to label on some of their clocks.
Right. The "First" quality Kienzle clock movements I've seen have the word "Prima" instead of the roman numeral "I". As you mentioned, there are little differences between the two "grades" that don't refer to inferior/superior quality. The Prima/First grade clocks seemed to have better gong assemblies, with dual coils instead of a singular coil.I know Lenzkirch used this system and would not be surprised if Kienzle did also. Second quality in Lenzkirch jargon did not mean inferior quality, just that the pivots of the movements were not as polished as the first quality movements - things of this nature.
Regards.
The 'wedding stuff' says:There is a lot of writing on the glass which is supposed to be wedding stuff.
Keep the writing!Should I remove the writing or keep it for history?
They are about the same quality. Perhaps your clock movement in this thread has solid pinions throughout, which would be a bonus.Thanks for the quick clarification. Should I remove the writing or keep it for history? Speaking of quality, this must be better quality then that other kienzle I had?
I just finished servicing that but it was the metal was very soft and bendy.They are about the same quality
Is this the cut pinion?solid pinions
Was it one of your wall chiming clocks?I just finished servicing that but it was the metal was very soft and bendy.
It’s a unmarked table clock. ButWas it one of your wall chiming clocks
