• Upcoming updates
Kienzle movement, What date and case?
pelops
Jan 8, 2011
21
I stumbled across this clock movement on a Bulgarian jumble stall this morning. I bought it just for the porcelain dial and hands but on getting home have found it to be fully wound and working, though very dirty. I believe its Kienzle, with the horseshoe star mark, serial number 1124730.
Would anyone know what type of case it should be in and a rough date?
It has a removable gong bracket /support, which must have attached to the cabinet, strikes on the hour and half, has an advance lever to move the strike forward every half hour (I'm afraid I don't know the technical term. Dead chuffed, as it cost me less than the equivalent of $5. Thanks in advance.
IMG_20221002_150240.jpg IMG_20221002_150336.jpg IMG_20221002_150538.jpg IMG_20221002_151117.jpg
KurtinSA
Nov 24, 2014
5,746
586
San Antonio, TX
Welcome to the forum! The mikrolisk database suggests that logo is for Konkurrenz brand which is a Carl Werner clock. Probably 1900 give or take a number of years.
Kurt
pelops
Jan 8, 2011
21
Thanks Kurt. I'm hoping that I might be able to find a case for it. Do you have any idea what length of pendulum it would need and are they all a standard length?
KurtinSA
Nov 24, 2014
5,746
586
San Antonio, TX
Others will know. Often there is a stamp of "PXX" on the back plate which is the length in centimeters. You can try searching the forum for "Konkurrenz" to see what might be out there.
Kurt
Reactions: pelops
Tatyana
Jan 2, 2016
711
288
Saint Petersburg
If you look closely, there are numbers 124 / 30 on the back wall of the movement..
This means that the length of the pendulum is 30 centimeters.124 - the number of movements of the pendulum.
More often Werner movements with the marking 104 / 42.
Regards
Tatyana
Reactions: pelops
pelops
Jan 8, 2011
21
Thanks Tayana. My mistake, I thought the / was a 7 when I posted. It gives me an idea what to look out for.
Incidentally I've discovered that the movement wasn't as dirty as I'd originally thought. I've just dusted the mechanism with a soft brush and wiped over the dial with some glass cleaner and its come up quite well.
Tatyana
Jan 2, 2016
711
288
Saint Petersburg
View attachment 729376 View attachment 729377 View attachment 729378
Catalog 1905 Часовой форум Watch.ru - Показать сообщение отдельно - Каталог Carl Werner 1905 год
Look for a case for this movement in the topic "Half regulators"
pelops
Jan 8, 2011
21
178,998
1,570,069
54,045
QMAC
909
3,088
Swiss Fake by Kent
