• Upcoming updates
Kienzle movement date
tonymedri
Mar 17, 2017
302446.jpg 302446.jpg Hi Guys
can anybody shed light on the kienzle movement I'm working on ,it would be good to date this the number stamped are 10348. With an additional number 22 stamped to one side of the back plate ,the front plate is stamped kienzle .Many thanks 302444.jpg 302444.jpg 302445.jpg
18,006
3,480
Tony,
Not a good idea to run a movement at the edge of a shelf like that. Bad things can happen.
Others will know about dating your clock.
Good luck, Willie X
J. A. Olson
Dec 21, 2006
5,049
790
WI
This is one of Kienzle's earliest Westminster chime movements, made around 1908-1912. The countwheel chime mechanism and removal spring barrel frame are notable features not present on later movements.
tonymedri
Mar 17, 2017
Hi Willie i can see your point
178,935
1,569,408
54,018
JBowers
909
3,087
Private Label Watch by Kent
