Picked up a little rough looking Kienzle Automatic for very little. Has a small amount of battery leakage and overall needing some cleaning. It will run if I manually activate the solenoid that winds the mainspring, so that's a good sign.
Ran into a little problem getting the movement out of the face plate, the spanner screwdriver nut is stuck. I have a few spanner blades but nothing deep enough to go over the stem. Never seen a tool that would fit this nut and using a screwdriver on one side with force is surely going to mangle it up. Applied a little Kroil penetrating oil on it and letting it soak overnight. Any idea's on where to find a tool?
