Hi Everyone,
I seem to be having a lot of bad luck recently!... I now have another query!
I have a weight driven kieninger movement. It has little wear. The problem is that it keeps stopping! I altered the distance of the verge from the escape wheel and all seemed to be well and it continued to keep ticking for 12 hours before it stopped again! Prior to the adjustment it would only go for 30 minutes hence why I presumed the fault was linked to the escape-verge distance.
When the clock does stop the minute hand is locked and upon giving the pendulum a push, there is no tick whatsoever.
Do you think that I need to widen the verge- escape wheel distance further?? The escape wheel in this movement has quite 'shallow teeth' compared to most other escape wheels that I have seen!
Any advice would be good? I have made three adjustments now but just wonder if there is something else amiss hence my message today?
(I personally keep thinking that it may be related to the escape- verge distance as on each adjustment the clock runs for a longer period of time before stopping??)
Thanks as always
Simon
Thanks as always
Simon
