Kieninger & Obergfell New Project
Les Sanders
Apr 3, 2010
765
26
Sahuarita Arizona
Well I just acquired this off of Ebay K&O plate1355 serial # 26951 It appears to be all original missing the suspension and the anchor is a minor joke eye screw. But it has a wonderful original heavy glass dome. So here are a few pictures.
Reactions: PatH and etmb61
etmb61
Oct 25, 2010
2,622
198
Mascoutah, IL
Hi Les,
That's a nice one. I have the same model in green that I purchased from a seller in Arizona.
Eric
etmb61
Oct 25, 2010
2,622
198
Mascoutah, IL
Actually mine came from Higley. It's in really good shape and complete too. Just needs repainted.
etmb61
Oct 25, 2010
2,622
198
Mascoutah, IL
I've not encountered any of this model with a painted base. Pendulum balls, support columns, and dials painted only.
KurtinSA
Nov 24, 2014
3,865
170
San Antonio, TX
I have a similar clock, although different plate 1151. The logo is Geo. Borgfeldt and higher serial number but all else seems the same. No painted base...mine is red.
Kurt
Kevin W.
22,703
409
Great looking clock. A very nice find.
etmb61
Oct 25, 2010
2,622
198
Mascoutah, IL
Wow! Nice job! Want to do mine too? (Just kidding)
What paint did you use?
KurtinSA
Nov 24, 2014
3,865
170
San Antonio, TX
Yes, would like to know the paint and your technique to cover the brass!
I think I notice that one of the fasteners that hold the movement onto the lintel seems a bit off vertical. I fight this when I reassemble a clock...I take some pains to make sure that the lower plate pillars are rotated to the best position...I use the fasteners to hold the pillars in place while I tighten the front plate screws. That usually keeps the pillars locked into position.
Kurt
instarclock
Mar 23, 2009
451
Galveston
You did a great job restoring your clock. I have the same model I bought several years ago from John Hubby. Needless to say, the clock runs perfectly. :)
Les Sanders
Apr 3, 2010
765
26
Sahuarita Arizona
The paint I used is Dupli-Color, this is available at Most Auto Parts Stores. I used paint remover and then a light sanding and 3 coats of paint.
Reactions: etmb61
mjstewart
Feb 20, 2016
39
Great job! I'm a big fan of these colorful clocks.
Staff online
161,034
1,397,114
82,997
Spiketock
1,099
2,788
