Outbavk_Joe
New User
- Feb 28, 2022
- 4
- 1
- 3
- 66
- Country
I have a new to me clock that I have been restoring over the past month and have a question.
This clock has a set of points that triggers the coil. Problem is that it fails to run on 1.5 Volts. It runs great on 1.85 Volts and seems to keep time. This clock was a real mess and badly corroded from an old battery when I received it so I don't know how the points should be adjusted or even what they should look like as they were bent in a very strange shape. I don't have any idea how bad the magnet is in the round tube that moves thru the coil.
Question what is the max voltage the coil should see on one of these clocks. Is any deviation in the 1.5 volts allowed?
