I'll try to be brief. I have the above named clock, magnet through a coil of wire. Cleaning the battery compartment terminals and installing a new battery yielded no positive results. There is a circuit board beside the battery compartment. I realize there are only so many components that can fail. What is the most likely point of failure? If it is the coil, can a replacement coil be obtained and where would I have luck finding one? Can any of you suggest any other troubleshooting measures I might try? The mechanics seem to function properly while the pendulum is swinging before stopping.
JJC
JJC
