Kieninger clock movement help
Discussion in 'Clock Repair' started by John P, Jul 14, 2017.
  1. John P
    John P Registered User
    NAWCC Member Donor
    Sep 17, 2010
    596
    Looking after the cats
    I need a spring barrel cap for this movement. Anyone have a source for the part.
    Its a skeleton type clock sitting on a wooden base with a glass dome over it.
    [​IMG]
    The only numbers I see is S 81 on the back plate
    thanks
    John
  2. wow
    wow Registered User
    Jun 24, 2008
    2,186
    Retired Music Minister
    Pineville, La. (central La.)
    Hey, John. First of all, it's sinful to have a work area that clean. Must be nice!!!
    Now, about the cap: does the one you have not fit?
  3. shutterbug
    shutterbug Super Moderator
    34,642
    44
    Try turning it over. They won't lock in upside down sometimes.
  4. John P
    NAWCC Member Donor
    Sep 17, 2010
    596
    I have the correct cap, its worn out in the center.
  5. dickstorer
    dickstorer Registered User
    Oct 19, 2010
    567
    Retired Military
    Hampton, Georgia
    If the center hole is worn it needs to have a bushing inserted.
  6. Willie X
    Willie X Registered User
    8,142
    32
    #6 Willie X, Jul 16, 2017
    If the arbor is badly worn it will need to be turned true on a lathe. Then rebush the cap as ds just mentioned. Make it a stepped bushing if you can, peened on the inside. Or at least a bushing that's a little thicker than the cap, peened into a chamfer on both sides.
    I agree with Wow, you need to clutter that place up a bit. You will never get anywhere with a workplace that clean! ☺
  7. John P
    NAWCC Member Donor
    Sep 17, 2010
    596
    I was hoping to purchase a new cap or spring barrel but if they are not available then that's what I will do.
    thanks
    john
  8. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    I work in computer design. There was one fellow that at the end of the day
    his desk was so clean that you'd think his office space was not even being
    used.
    I'd always had the saying " empty desk, empty mind " but it surely didn't
    apply to this fellow. I can only assume he kept his desk in his mind.
    There was never any lacking in his work. He was at the top of the best.
    It is a shame he died of cancer a few ago. He was only 52 years old.
    I see different strokes for different folks.
    Now I have to go and clean my desk.
  9. John P
    NAWCC Member Donor
    Sep 17, 2010
    596
    All this talk about a clean work area. Next time I post a picture of something, I'll stage it with rusty bolts. bent up clock parts and an ash try full of cigar butts. HA..
    Oh, trimmed the hole in the cap round, made a bushing, pressed it in, reamed bush to fit arbor, clock is running fine.
Similar Threads - Kieninger clock movement Forum Date
Kieninger "J" Wall Clock Movement Clock Repair Sep 14, 2017
Herman Miller Clock w/Kieninger SEW01 Movement Running Very Fast! Clock Repair Aug 4, 2017
Kieninger clock movement question Clock Repair Jan 7, 2017
Kieninger Grandfather Clock Movement Clock Repair Aug 3, 2013
kieninger movement (grandfather clock) Clock Repair Jun 12, 2012
