Key wind, Key set Swiss help
Discussion in 'European & Other Pocket Watches' started by Tim Fitzgerald, Oct 26, 2019.
  1. Tim Fitzgerald
    Tim Fitzgerald Registered User
    Jan 2, 2016
    659
    373
    Artist
    Oak island North Carolina
    I am trying to find information on this Swiss 33.6mm key wind key set movement . It has a serial number #3617
    it has no dial or case and runs very well. The only other writing on the movement is " fast or slow ' on the balance cock. Can anyone help?
    TimFitz
  2. jess tauber
    jess tauber Registered User
    Dec 24, 2017
    134
    30
    This is a Jules Jurgenson STYLE movement. A number of makers used them for their own products.
    Jess Tauber
    Tim Fitzgerald likes this.
  3. Tim Fitzgerald
    Jan 2, 2016
    659
    373
    Artist
    Thanks Jess, I am an American P/W collector & am lost with Swiss movements. Do you know what size this is If I wanted to case it in and get a dial?
    timFitz
  4. jess tauber
    Dec 24, 2017
    134
    30
    You might want to check out this chart for case sizes: Pocket Watch Sizes & Measurement Chart: 18s, 16s, 12s | Pocket Watch Database
    Just remember that when this movement was produced (likely before machine-tools became commonplace), adherence to standard sizes was more hit or miss than reliable, so finishers had to fit the case to the movement. With luck you'll find something that works (not too tight or too loose). Your case will still have to be adjusted for the pin on the edge of the movement to help keep it from rotating in the case, and getting the key holes lined up is another issue. The time-setting arbor isn't a problem being in the center, but the winding arbor may not be where it needs to be. Some folks had mismatched cases 'repaired' (filling the unused hole and putting a fresh one in the right place). Good luck!
    Jess Tauber
  5. Tim Fitzgerald
    Jan 2, 2016
    659
    373
    Artist
    Thanks again Jess!
    TF
  6. Keith R...
    Keith R... Registered User
    Nov 27, 2012
    5,525
    1,962
    Retired Sr. Proj. mgr,
    South
    These ebauches are a typical better grade of 15J watches for various retailers Tim.
    One of mine from 1855.
    Keith R...
    100_3868 (1600x1200).jpg FM2 (798x800).jpg FM5 (1004x1024).jpg FM3 (675x800).jpg
    viclip and Tim Fitzgerald like this.
  7. Tim Fitzgerald
    Jan 2, 2016
    659
    373
    Artist
    Thanks keith
    Keith R... likes this.
  8. Keith R...
    Nov 27, 2012
    5,525
    1,962
    South
    #8 Keith R..., Oct 26, 2019
    I recall about 6 variations on this setup. Cleaned and timed, they are accurate pieces.
    You might have to find an unsigned dial. Hunters mostly and 15J.
    This one about 16 size.
    Threw in a Russian.
    Good luck Tim.
    Keith R...
    103_7672 (800x600).jpg 103_8299 (800x600).jpg JJ765 (800x600).jpg JJ766 (800x600).jpg
    viclip likes this.
  9. jess tauber
    Dec 24, 2017
    134
    30
    Dials are another thing- the dial feet (the small pins on the back side of the dial) may not be in the same alignment as their holes on the movement, either in terms of radius from the center of the dial versus the movement, or their orientation on the movement, so that the seconds subdial aligns with the hole in the movement. Its easier probably to get a repair person to remove existing pins and then replace them with ones that do align.
    Jess Tauber
  10. Les harland
    Les harland Registered User
    Apr 10, 2008
    1,386
    114
    Hertfordshire England
    No one has mentioned that Fast and Slow mean that the watch was made for the English speaking market
    Normally Swiss movements are marked Advance and Retard French for fast and slow
    British and European watches are a different world to American ones
    Then there are Hall Marks to understand
  11. jess tauber
    Dec 24, 2017
    134
    30
    I've never seen Avance spelled Advance, which is the English cognate. Did anyone actually do this?
    Jess Tauber
  12. Les harland
    Apr 10, 2008
    1,386
    114
    That is a good point Jess
    I will have to look more closely at my watches
