KERN + SOHN in brasscasted housing
DieteR
Sep 18, 2008
139
11
Hello
At this point I present a few photos
from my new KERN (K. u S. M IV Plate 1406G).
The special feature of this clock is the triangular (hexagonal) case.
I suspect that the brass castings are electrogalvanised gold-plated.
Who can tell me the easiest way to test?
DieteR
DSCI2090.JPG DSCI2078.JPG DSCI2079.JPG DSCI2082.JPG DSCI2085.JPG DSCI2089.JPG
KurtinSA
Nov 24, 2014
4,314
256
San Antonio, TX
Very pretty! What do you mean to "test"? Looks like the top will lift off once the clips are moved. Then, wind the clock, and make sure the beat is set.
Kurt
MartinM
Jun 24, 2011
3,091
112
El Dorado, CA
I don't believe they are actual brass parts, DieteR.
DieteR
Sep 18, 2008
139
11
Kurt
The clock runs fine!
I want to test, if it is electrogalvanised gold-plated
MartinM
Why You don't believe they are actual brass parts? What do You think, the parts are made from?
DieteR
MartinM
Jun 24, 2011
3,091
112
El Dorado, CA
While I'm sure there could have been variations, over the years, I had a similarly constructed full size Kern where the dial included a place where there was a spot of the plating missing (I'm guessing due to corrosion, but it could have been damage from a drop). If I had to guess, I'd say it was spelter, underneath. Dark gray like cast iron. and not soft like tin, lead or pewter.
DieteR
Sep 18, 2008
139
11
You are right. It is definitly no BRASS!
It is no iron, because it is not magnetic.
After testing the top cover on it's underside, the material is silvery and softI
It's probably tin, or, at best zinc die casting.
DieteR
MartinM
Jun 24, 2011
3,091
112
El Dorado, CA
DieteR
If you really want to know what metal it is, maybe Herr Kern could be of help. As far as I know, he still replies to questions about their clocks. If he does reply, let us know just as a matter of record.
Jahresuhren / Homepage
victor miranda
Jan 13, 2017
374
47
Baltimore
brasses include a grey color metal.
less copper than the yellow brass.
think more zinc and less copper.
it is supposed to be easy to cast...
victor
165,482
1,440,547
86,256
eeclone
2,873
