Kern & Link standard, dial restoration advice
Phil G4SPZ
Oct 18, 2018
587
95
68
Bewdley, Worcestershire, UK
I was very lucky to have been given this 1932 Kern & Link plate 1667 standard 400-day clock. It's the early model, having no pendulum locking mechanism or levelling adjusters. Apart from being very dirty, it is complete apart from its missing dome, and I am just embarking on restoring it.
The dial is peppered with spots that look like rust, but aren't.
Can anyone please suggest how I might go about cleaning and restoring the dial, or at least improving its appearance a little? I obviously don't want to make matters worse or cause any irreparable damage. Any advice would be much appreciated!
Many thanks,
Phil
Dells
Oct 18, 2019
474
80
In the cotswolds UK
Hi Phil
That dial looks silvered in picture if it is then cream of tarter worked on a Westminster chime silvered dial for me but try in an inconspicuous place first.
Dell
Phil G4SPZ
Oct 18, 2018
587
95
68
Hi Dell,
No, it’s a brass-coloured finish rather than silver. Difficult to capture in a photograph.
I’ve tried very gentle cleaning with a moistened Q-tip but it had no effect. I think the surface has degraded, rather than simply being dirty. Not wishing to damage the dial, I think I will probably live with it as evidence of the clock’s age!
Phil
46,425
1,858
Good idea. The numbers on those are often just water soluble paint, and you can lose them easily.
Phil G4SPZ
Oct 18, 2018
587
95
68
I have decided to replace the dial. The new dial has Roman rather than Arabic numerals. I will store the old dial carefully beneath the clock’s base, in case some future owner wishes to restore the original.
Phil
Phil G4SPZ
Oct 18, 2018
587
95
68
Thanks, both! Any vestiges of lacquer on the plates and base had long since disappeared, and the brass responded well to conventional polishing.
How to keep it looking shiny and prevent tarnishing is my next question. I have used liquid wax polish on brass before, with quite good results, but a product called “Renaissance” micro-crystalline wax polish has been highly recommended by friends who restore brass oil lamps. Any other recommendations?
Incidentally, the old dial is now safely stored inside the dial pan, alongside another white printed dial that was already in there!
Phil
whatgoesaround
Jan 22, 2008
521
37
south carolina
From what I have read on here that is a good product and any high carnauba wax is supposed to be good. I think the wax is chosen because when it is time to clean again, it removes easier than a lacquer. Others on here can correct me if I am wrong. Personally, I have recently gone to lacquer, because I feel it lasts longer. Choice of lacquer is very important since some leave a cloudy appearance. I have used Mohawk lacquer and like it, but I will bet there are others that can do as well or better.
Dells
Oct 18, 2019
474
80
In the cotswolds UK
Hi Phil
I use Renaissance wax and I have found that the brass doesn’t tarnish very quickly but I have to use white gloves when handling as fingerprints mark it very easy.
Dell
Phil G4SPZ
Oct 18, 2018
587
95
68
Thanks for the tip, Dell. I do use white gloves, but I will pay special attention to any waxed areas.
165,478
1,440,499
86,255
ememess
2,873
