Keininger Verge Depthing
Les Sanders
Apr 3, 2010
871
41
Sahuarita Arizona
What were they thinking slotted holes to retain the verge mount! I normally just split the difference not today it hates me! Anyone have a sure fire way to set these up?
wow
Jun 24, 2008
5,846
747
76
Pineville, La. (central La.)
Les, I tighten the two screws just tight enough that they hold the mount but will still slide. Then I lower both sides so the escape wheel locks. Then very slightly move each side up until the escape wheel escapes. That should be close.
15,586
2,113
I snug down one side (near the center) and leave the other side loose for adjustment. Adjust until the pallet is just deep enough so the pallets clearly drop onto the dead faces. About 15 thou, up from the impulse face, is usually good.
When all is correct, snug down both screws and recheck. It makes no difference if the hanger is slightly askew. Willie X
48,139
2,387
I snug up both screws and get to the right spot with light taps on the sides. No pendulum for this adjustment. Then lock it down, mount the pendulum and test.
170,894
1,491,943
49,975
PhillipsRobertson
2,967
