Thank youThe back plate doesn't really match those in the repair guide, but the closest I could find is #1311. It does take a 0.003" spring if needed.
Kurt
thanksI did a thread maybe 3 years ago on a Kaiser I was working on. If I can find it I will post rhe link.
Kurt
Many thanksHere's the thread where I detailed some of the rebuild steps of my Kaiser. In the repair guide, there are pictures which show how the various parts are stacked when going back together. I do recall it being tricky to get things tight enough but not too tight. I think one issue I was having was I could get things tight, but then when I was turning the adjuster the opposite direction, it loosened things up. It's got to go together correctly for things to work.
Kaiser Universe Overhaul | NAWCC Forums
Kurt
Here is a picture of the stack up of parts for the pendulum. That retaining clip is a non-standard part.
Kurt
Oddly it measures as a whitworth thread let me know how long it is I have a few in a box.Cheers for that Kurt, everything seems to be working well so I'm leaving my set up as it is. There's another issue, one of the studs that connect the top and bottom of the clock has been sheared at some time so now it is too short. What is the thread size for this?
John
