K&O Runs without hands, stops with hands attached
Discussion in '400-Day & Atmos' started by Uncle Lem, Jan 15, 2020.
  1. Uncle Lem
    Uncle Lem Registered User
    Jul 26, 2013
    145
    Just finished cleaning a 50's era K & O 400 Day and replaced the torsion spring using the Horolavar book as a guide. The clock runs fine before the hands are attached. It will also run with just the hour hand attached. The minute hand is held by a pin, and as soon as it is attached, the clock will run a few minutes and then stop.
    Added info: The flat and spring washer on the canon pinion don't provide enough tension to keep the minute hand from flopping, but if I shim it to give it tension, the clock stops.
    Any help is greatly appreciated.
  2. victor miranda
    victor miranda Registered User
    Jan 13, 2017
    374
    47
    computer programming stuff
    Baltimore
    k... the obvious is that the spring is adding drag...
    is a picture of the installation possible?
  3. Kevin W.
    Kevin W. Registered User
    22,605
    387
    I had this problem recently on a 400 day clock i worked on. I turned the nut over and that solved the problem for me.
  4. Ed O'Brien
    Ed O'Brien Registered User
    Nov 30, 2009
    633
    25
    Retired, and now full-time clock repairs.
    Winter Park, FL
    Maybe swap taper pin on minute hand for one just very slightly thinner.
  5. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,059
    105
    El Dorado, CA
    Make sure the hour hand is pushed onto its wheel far enough that the minute hand isn't rubbing on it.
  6. Uncle Lem
    Jul 26, 2013
    145
    Bingo! I'm a tad embarrassed that I didn't think of that. Thanks a bunch.
    Kevin W. likes this.
